John Morley
| Problem with serial output on 12F675 |
Posted: Fri Jun 24, 2011 1:38 pm |
Hi All,
I'm having a problem sending serial data from a 12F675. This design uses two A/D inputs to measure the output of a couple of sensors, and then controls a warning lamp connected to an output pin. There is also a pin assigned to send diagnostic messages for troubleshooting/development purposes.
Everything is basically working OK, but my diagnostic messages are not printing correctly. I have a stripped down version of the code that shows the problem:
#include <12F675.h>
#device ADC=10
#fuses INTRC_IO, NOWDT, NOBROWNOUT, NOPROTECT, NOPUT, MCLR
// Here we configure the internal 4 MHz oscillator....
#define Range_Input PIN_A3
#define Current_Input PIN_A2
#define Lamp_Output PIN_A5
#define Data_Output PIN_A0
// Here we configure the diagnostic serial LCD module....
#use rs232(baud=9600, xmit=Data_Output, stream = LCD)
void Blink_LED(int8 NumBlinks)
int8 iIndex;
for (iIndex = 1 ; iIndex <= NumBlinks ; iIndex++)
output_high(Lamp_Output);
delay_ms(350);
output_low(Lamp_Output);
delay_ms(350);
int16 Value;
int1 bIs28V;
// Here we turn off unused peripherals....
setup_timer_1(T1_Disabled);
setup_vref( FALSE );
//Here we set the initial state of the lamp output
// Here we configure the A/D converter module....
// Range Sensing will be on pin 'AN3' and Current Sensing will be on pin 'AN2'....
setup_adc_ports(sAN2 | sAN3 | VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel(Range_Input);
delay_us(10); // Delay to allow the channel to be acquired
Value=read_adc();
if (Value > 600)
Blink_LED(6);
bIs28V = True;
Blink_LED(3);
bIs28V = False;
// Here we have some basic diagnostic printing....
fprintf(LCD, "Range: %lu\n\r", Value);
fprintf(LCD, "Is28V: %u", bIs28V);
fprintf(LCD, "\n\r");
while(1); //end here
When I run this code, I see the following printed to a Hyperterminal window:
V: 0
As you can see, most of the diagnostic message is cut off, except for the last few characters of the 2nd line.
Interestingly, if I comment out the call to the 'Blink_LED' subroutine above, it prints correctly. The problem is NOT this subroutine, however, because the issue returns if I insert any small delay directly ahead of the fprintf statements.
I assume that my serial output pin is not being configured properly, but I don't know what that issue might be. I tried to turn off all other pin functions that I'm not using.
127675 is being powered by a well filtered 7805 voltage regulator.
My compiler is v4.050
Thanks,
John _________________ John Morley |
Posted: Fri Jun 24, 2011 2:01 pm |
What's the manufacturer and part number of the LCD ?
Has it ever worked ?
What happens if you strip the program down, cutting out 90% of the
code and merely have a main() with a delay at the start (say, 1000 ms)
and then do a printf with a while(1) at the end ? Does it then work ?
Aside from that, here are a few other comments:
| Quote: |
ADC channel numbers must be 0, 1, 2, 3, etc., not CCS pin numbers.
| Quote: |
12F675 Data sheet pinout for pin 4: GP3/MCLR/VPP
If GP3 is configured as the MCLR pin, it can't be used for i/o and must
have a 10K pull-up on it. It's dedicated to being an MCLR (reset) pin only.
In fact, is it possible that you're resetting the PIC with an analog signal
coming into the MCLR pin ? Remove everything from that pin except the
10K pullup.
| Quote: | | setup_adc(ADC_CLOCK_INTERNAL ); |
The 12F675 data sheets says (in the ADC section), to use this divisor
for 4 MHz operation:
John Morley
Posted: Fri Jun 24, 2011 2:59 pm |
When things did not go as expected, I added a MAX232 to my circuit, and I'm now viewing the diagnostic messages on Hyperterminal. I also tried RealTerm, so it's not the terminal client that is causing the problem.
I have a 10K pull-up on MCLR, and I changed the ADC clock to "ADC_Clock_DIV_8"
I think a problem is my confusion with physical pin numbers, pin references, and analog input references? I think I've corrected that, but the problem persists.
My hardware is connected as follows:
The digital output to the lamp is on physical Pin #2
One analog input is physical pin #3
One analog input is physical pin #5 (not used in my test example)
Diagnostic data is sent to physical pin #7
The datasheet lists pins GP0 thru GP5, and the pin references in the 12F675 header file are Pin_A0 thru Pin_A5. I assume they correspond? The A/D references are 'sAN0', 'sAN1', 'sAN2', and 'sAN3'.
Here is an updated version of the code:
#include <12F675.h>
#device ADC=10
#define Range_Input PIN_A4
int8 iIndex;
delay_ms(350);
delay_ms(350);
int16 Value;
int1 bIs28V;
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(3);
Value=read_adc();
if (Value > 600)
Blink_LED(6);
bIs28V = True;
Blink_LED(3);
bIs28V = False;
If the 'Blink_LED' routine is executed, the diagnostic message is not printed correctly. If I comment this part out, I see the message as expected with a valid A/D reading being displayed.
Thanks,
Posted: Fri Jun 24, 2011 4:25 pm |
It works for me. I get this output on TeraTerm:
| Quote: |
Range: 56
Is28V: 0
Range: 127
Is28V: 0
I ran the program twice. That's why there are two sets of output.
I didn't use a MAX232. I used a direct rs232 connection, just to save time.
I took your latest program and added the INVERT parameter to the
#use rs232() statement. Then I connected pin A0 directly to the Rx pin
on the COM port connector on my PC (with a cable). Also, I connected
ground from the board to the ground pin on the COM port. The board
is a Microchip "low pin count" board. I programmed the 12F675, and
then removed the Pickit 2, and supplied power to the board from a
+5v bench power supply. The program was compiled with vs. 4.050.
I'm sure it would work just fine if I used a Max232 and didn't use the
INVERT option.
My guess is, maybe look for a solder short on your board ? Or check the
power supply voltage and stability ? |
John Morley
Posted: Sun Jun 26, 2011 7:51 pm |
Hi pcm!
Thanks for making those tests for me!
I'm not sure whats going on, but I can reliably cause the serial output to become corrupted simply by including the Blink_LED routine. It's a handwired prototype, so it's possible that there is a short, or some crosstalk going on that is specific to this prototype. I'm going to have a PCB built now for this project, and I'll report back when I have it to let you know whether the problem is solved or not!
Thanks,
Posted: Mon Jun 27, 2011 2:41 am |
You have got a resistor between the PIC output, and the LED?. If not you will be overloading the PIC when you 'blink' the LED, and anything could happen....
John Morley
Posted: Mon Jun 27, 2011 9:21 am |
The 'LED' will actually be an incandescent warning lamp in the final application, so it's being drive by a small N-channel MOSFET connected to the PIC output pin.
Thanks for the suggestion!
