orangeshasta
| Microchip HID Bootloader with PIC24F |
Posted: Thu Apr 28, 2011 9:37 am |
Hi all,
I'm trying to get Microchip's HID bootloader with a project I have running on a PIC24FJ256GB106. I've got the bootloader itself running properly, and I can successfully load and run a simple "Hello World" program which just prints out of the UART, delays 1000ms, and repeats.
However, when I load code that involves interrupts, things stop behaving. I've narrowed down the problem, and it looks like the CCS compiler isn't remapping my interrupts the way I expect.
Anyway, here's some code:
#include <24FJ256GB106.h>
#device adc=10
#FUSES NODEBUG
#FUSES ICSP3 //ICD uses PGC3/PGD3 pins
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES NOOSCIO //OSC2 is not general purpose output
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES PR_PLL //Primary Oscillator with PLL
#FUSES PLL2 //Divide By 2(8MHz oscillator input)
#FUSES NOJTAG
#use delay(clock=32M)
// START OF bootloader definition
#define LOADER_END 0x13FE
#build(reset=LOADER_END+2, interrupt=LOADER_END+6)
#org 0, LOADER_END {} // nothing will replace the bootloader memory space
// END OF bootloader definition
// Variable definitions, interrupt service routines, main, etc. below here
So, I've set aside program memory between 0 and 0x13FE, which is taken up by the bootloader. Because that is the space where the reset and interrupt vectors are, the reset vector gets remapped to 0x1400 and the interrupts should start at 0x1404, according to the datasheet and the bootloader documentation. My code uses a lot of interrupts (EXT1, Timer1 - Timer5, RDA, TBE, and RDA2), and I can see in the start of my .lst file where they are remapped:
01400 0457FE 000000 GOTO 57FE :
01430 042150 000000 GOTO 2150 :
01440 042174 000000 GOTO 2174 :
01444 0421F4 000000 GOTO 21F4 :
01450 042314 000000 GOTO 2314 :
01454 04241E 000000 GOTO 241E :
01474 041D66 000000 GOTO 1D66 :
01490 042216 000000 GOTO 2216 :
01494 0422E0 000000 GOTO 22E0 :
0149C 0424EE 000000 GOTO 24EE :
That second instruction (GOTO 2150), for the sake of example, is my Timer1 ISR. As you can see, that instruction is located at 0x1430. However, according to the linker file in the Microchip bootloader, it should be located at 0x1424. The other interrupts are similarly offset by +6. I can't change my #BUILD statement to have the interrupts mapped to a location 6 words earlier, because that's space set aside for the bootloader. Does anyone have any idea how I might be able to get these mapped properly?
Thanks in advance,
Bob
P.S. Also, I am using the most up-to-date version of the compiler: v4.120 |
cfernandez
Posted: Mon Jun 20, 2011 6:19 pm |
Dear
You solve this problem?, Can you tell me. I have similar problem
Regards, |
orangeshasta
Posted: Tue Jun 21, 2011 8:11 am |
Not really - as it turns out, the method that CCS provides for remapping the IVT doesn't allow for making the interrupts have four bytes in between each one, as Microchip does (to hold a GOTO instruction). Therefore, it would not be straightforward to make the Microchip HID bootloader work with the CCS compiler.
The only way I know of to simply make it work would be to hard-code all of the the IVT memory locations in Microchip's linker script, using only 2 bytes for each entry. This was suggested to me by Microchip support - however, I'm not too familiar with the syntax, etc. of the Microchip linker file and so I decided that I needed to move on with my project rather than spend more time trying to get the bootloader to behave.
Let me know if you come up with anything though, I'd be curious to hear how you did it. |
FvM
Posted: Tue Jun 21, 2011 9:32 am |
One option with the Microchip HID bootloader is to use no mapping at all, make the bootloader code write the complete IVT from PCD application image, except for the reset vector, that points to the bootloader into page 0. This brings a certain risk of bootloader failure, because you need to unprotect the bootloader area.
A fail safe bootloader must have all used interrupt vectors fixed, e.g. by using predefined ISR addresses. |
