Unstable behavior on Pic Master I2C with 2 Slaves
gonlo82
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Jun 20, 2011 10:46 am     Reply with quote
Hello. I'm a CCS(ver 4.3.0.278) beginner programmer. I trying to fix an unstable behavior between a master and 2 slaves 16f876a Pics. If a connect only a master with only one slave they work well. The master collect the info and shows it in a lcd. But when there are 2 slaves connected the info is altered after 4 secs showing the max value acquired by the two slaves through their pins AN0.
I attach the codes below and a picture below. I hope receive some help.
MASTER
#include <16f876a.h>
#fuses XT,NOWDT,NOPROTECT,PUT,NOBROWNOUT,NOLVP
#use delay(clock=4M)
#define LCD_DATA_PORT getenv("SFR:PORTB")
#define LCD_ENABLE_PIN  PIN_B2
#define LCD_RS_PIN      PIN_B0
#define LCD_RW_PIN      PIN_B1
#include <lcd.c>
#use i2c(MASTER,SDA=PIN_C4, SCL=PIN_C3/*,FAST,FORCE_HW*/)
#use fast_io(c)
int8 lee_master,escla1,escla2,escla3,escla4,escla5,escla6;
int8 ack=5;
void read_i2c(int dir); // Función que escribe en el PIC esclavo.
   lcd_init();
   while(true)
     //if(input(PIN_a0)==1)
     read_i2c(0xA1);// Leemos un byte del dispositivo con id=0xA1
     escla1=lee_master;
     delay_ms(10);
     lcd_gotoxy(1,1);
     printf(lcd_putc,"\fESCLAVO 1\n");
     //lcd_gotoxy(1,2);
     printf(lcd_putc,"%3u",escla1);
     delay_ms(2000);
     //if(input(PIN_a0)==0)
     read_i2c(0xB1);// Leemos un byte del dispositivo con id=0xA1
     escla2=lee_master;
     delay_ms(170);
     lcd_gotoxy(1,1);
     printf(lcd_putc,"\fESCLAVO 2\n");
     //lcd_gotoxy(1,2);
     printf(lcd_putc,"%3u",escla2);
     delay_ms(2000);
void read_i2c( int dir)
   i2c_start();
   ack=i2c_write(dir);//This function returns the ACK Bit.
  // 0 means ACK, 1 means NO ACK, 2 means there was a collision if in
  //Multi_Master Mode. This does not return an ACK if using i2c in slave mode
   delay_ms(10);
   lee_master=i2c_read(0); // 0 means ACK
   delay_ms(10);
   i2c_stop();
SLAVE
#include <16f876A.h>
#fuses /*XT,*/NOWDT,NOPROTECT,PUT,NOBROWNOUT,NOLVP
#DEVICE ADC=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3,ADDRESS=0xB0/*, FAST , FORCE_HW*/)
#use standard_io(b)
#use fast_io(a)
#use fast_io(c)
int8 q,r=0;
float p;
int8 estado=0,status[6];
int8 dato[6];
int8 i=0,j=0;
#int_SSP
void SSP_isr()//Returns the state of I2C communications in I2C slave mode
               // after an SSP interrupt.+ state is an 8 bit int
   estado=i2c_isr_state();//detecta el estado del bus i2c
   if(estado>0 && estado<0x80)      // el esclavo recibe datos
   {//0x7F - Master has written data; i2c_read() will immediately return the data
      i++;
      dato[i]=i2c_read();
   else if(estado >= 0x80)       // maestro lee dato o el esclavo escribe datos
      j++;
      status[j]=i2c_write(q);
      delay_ms(10);
   }/*0x81-0xFF - Transmission completed and acknowledged; respond with i2c_write()
   to pre-load the transmit buffer for the next transation (the next I2C read
   performed by master will read this byte).
    setup_timer_1(T1_DISABLED);
    setup_vref(FALSE);
    enable_interrupts(INT_SSP);
    setup_adc_ports(AN0);                                   //Canal 0 analógico
    setup_adc(ADC_CLOCK_INTERNAL);    //Fuente de reloj RC
while(true){
      set_adc_channel(0);
      delay_us(20);
      q = read_adc();                  //Lectura canal0
      p = 5.0 * q / 255.0;           //Conversión a tens
PROTEUS SIMULATION (VER 7.7.2)
[img]http://imageshack.us/photo/my-images/42/masterwith2slaves.jpg/[/img]
I m working for me in electrical troobleshooting. Pic's Matter interest me a lot to improve my skills.
PostPosted: Mon Jun 20, 2011 12:18 pm     Reply with quote
quick comments
1) get rid of the fast_io commands !! Unless YOU setup the I/O ports correctly using the set_tris... commands, you'll have a LOT of trouble. Let the compiler automatically handle the ports!!
2) Do you have the correct pullup resistors on the I2C bus lines ?
3) The /* */ in the code is very confusing to me, maybe the compiler as well. It's easier to make 2 similar statements and comment out the one not being tried.
4) I'd setup all peripherals BEFORE enabling any interrupts just to be certain all is correct before the ISRs are enabled.
5) Get rid of Proteus. It is FULL of bugs,errors and other bad things !
PostPosted: Tue Jun 21, 2011 1:28 pm     Reply with quote
This 2-page thread discusses problems and solutions for making 2 or more
PIC i2c slaves work with one PIC i2c master:
http://www.ccsinfo.com/forum/viewtopic.php?t=39242
Study it carefully. For example, it does not put 10 ms delay in the slave's
#int_ccp isr (which you are doing). Try to make your code do it the
same way as the working code.
