future
Table search algorithm |
Posted: Thu Jun 10, 2004 7:09 pm |
I am writing some code to deal with table searchings and lookup.
This routine returns the position a given number is at some table.. based in this number it will lookup another. Example:
10, 20, 30, 40, 50, 60, 70, 80, 90, 100 // size 10
if value=55 then it would return 5
It is returning 0 and I can't find why, in simulator it is fine, but in real hardware id does not.
*pointer points to a array[8] inside a struct and &struct.array[0] tells the first address, sizeof(struct.array) tells the size (8 in this case).
Code: | table_search(*pointer, size, value) {
int8 count=0;
while((value>*pointer)&&(--size)) { count++; pointer++; }
return count;
Posted: Thu Jun 10, 2004 11:02 pm |
You need to post a complete test program, that we can drop into
MPLAB and test. It should be a small program, but you should post
all #use statements, #fuse statement, etc. |
Posted: Fri Jun 11, 2004 1:50 am |
Maybe it is a typo but in your example you put a value instead of address.
table_search(*pointer, size, value) is incorrect, use
table_search(pointer, size, value)
In CCS C if you declare table_search(char *pointer, size, value)
and you call it as table_search(&table,.....)
then it puts the lower byte of the address of the table. That is usually greater than 55. |
Re: Table search algorithm |
Posted: Fri Jun 11, 2004 4:23 am |
future wrote: | I am writing some code to deal with table searchings and lookup.
int8 count=0;
return count;
Series of comments.
First your declarations should include 'types'. Your declaration does not say what 'pointer' is a pointer _to_. C needs this, to know how to handle arithmetic on the pointer.
Second, use 'return(count)', rather than 'return count'. CCS sometimes has problems with the second type of declaration.
Generally, learn to be explicit in all declarations in CCS C. Though there is a 'default' in C, that a function returns a default sized integer if not declared, it is generally safer throughout, to declare everything. The code seems to work across more compiler versions with less problems if this is done.
int8 table_search(char *pointer,int8 size,char value) {
int8 count=0;
return(count);
Remember also, that the 'table' will need to be in RAM, and not a constant table in ROM for this to work.
future
Posted: Fri Jun 11, 2004 6:59 am |
Ttelmah thank you for the explanations.
It is very strange because this routine is called 2 times and only one works in hardware... I think this one will be hard to debug ;(
In SIM I watched all variables, pointer, size, value... all Ok in both calls.
Tables are arrays within structs, two 8 position arrays... pointers to them are 245 and 253. |
Posted: Fri Jun 11, 2004 7:46 am |
future wrote: | Ttelmah thank you for the explanations.
Now that description really is 'strange'. Seriously, I'd be looking at something else. For instance, is it possible that an interrupt may be occurring inside the second call?. Is it possible that the contents of the comparison array itself is being corrupted by something else?.
I'd look to adding a massive 'debug' at the entry to the call. Dump the memory area addressed by the pointer to RS232, or copy it to EEPROM, and then look at this after running the chip. Also copy the comparison value, and the size being passed....
future
Posted: Fri Jun 11, 2004 5:06 pm |
Ttelmah, I found the problem... and the cause was me
I Forgot that one item in the struct was int16, so everything after it was offset by 1 byte and the value of the first item in table was high... that's why it was always returning 0. |
Posted: Sat Jun 12, 2004 2:21 am |
future wrote: | Ttelmah, I found the problem... and the cause was me
I know the feeling all too well...
At least you have 'cracked' it now.
wgalaugher
table search algorithm |
Posted: Wed Jun 15, 2011 9:25 am |
I was looking for this topic and ran across this thread. Its quite old and thin on details.
I need some help to define the structure of the table.
if value=55 then it would return 5.
int8 count=0;
return count;
Posted: Wed Jun 15, 2011 1:37 pm |
When you copy code, then make sure to read the whole thread. Code: | table_search(*pointer, size, value) { | As mentioned in a comment above, this line is wrong.
Always post your compiler version.
Always post a complete test program. |
wgalaugher
Posted: Wed Jun 15, 2011 3:12 pm |
I got that part. Thanks.
What I'm looking for is the structure of the data array. The guy who posted the original did not provide all the code and that was back in 2004. |
Posted: Wed Jun 15, 2011 4:00 pm |
Only now I see that most of your post is a literal quote of the topic start. It helps a lot when you mark the quote so it is recognizable as a quote, now it is not clear what your question is. Use the 'quote' buttons to mark text as a quote next time.
The original topic poster used an array inside a struct, but for the working of the search function this is irrelevant, the search function expects an array and doesn't care how many layers you wrap around it. Something like the following will do the trick: Code: | #include <18F458.H>
#fuses HS,NOWDT,NOLVP
#use delay(clock=16000000)
int8 table_search(char *pointer, int8 size, char value)
int8 count=0;
return count;
char Array[] = {10, 20, 30, 40, 50, 60, 70, 80, 90, 100}; // size 10
int8 Position;
Position = table_search(Array, sizeof(Array), 55);
for(;;);
} | Tested in MPLAB simulation and found: Position = 5 |
wgalaugher
Posted: Wed Jun 15, 2011 4:12 pm |
Thank you
I'm a little new to the forum, but I learn fast. Sorry for the confusion!
Its amazing when you see how its done, how simple it is. I danced all around the target with all kinds of attempts that were close. But close doesn't cut it in coding.
I was trying to replicate a lookup function in pbasic. This will do.
Thanks again
Wayne |
wgalaugher
Posted: Wed Jun 15, 2011 11:20 pm |
I got the code working as advertized.
When I filled the array with the following:
char array [] = (1800,2001,3500,4001,7000,7351,10100,10201,14000,14351,18068,18169,21000,21451,24890,24991,28000,29701);
it returns a position of 1 for a value of 7001 or any other value between the min or max of the array.
I think I'm over an int value of 256. I've changed all the variables to unsigned int16 but no joy.
Is this doable
Wayne |
Posted: Thu Jun 16, 2011 7:38 am |
wgalaugher wrote: | I think I'm over an int value of 256. | Yep.
Post your actual code. The line you have posted now does not compile because the array is enclosed in '()' instead of '{}'.
Quote: | I've changed all the variables to unsigned int16 but no joy. | Did you also chance the char* pointer in the declaration of the search function? Otherwise it will treat the array as 8 bit integers...
A small but important thing to overlook is the 'sizeof' operator that I used in the example program. It will return the size of the array in bytes. As long as your array contains byte size elements it is an easy method to count the number of elements in the array. Now that you changed to int16 it doesn't work anymore as expected. See the improved version below.
#define NR_ELEMENTS(x) (sizeof(x)/sizeof(x[0]))
int8 table_search(int16 *pointer, int8 size, char value) // <<--- note the int16 *
int8 count=0;
return count;
int16 Array[] = {1800,2001,3500,4001,7000,7351,10100,10201,14000,14351,18068,18169,21000,21451,24890,24991,28000,29701};
int8 Position;
Position = table_search(Array,NR_ELEMENTS(Array), 21002); // changed the automatic array calculation to be more flexible for other data types
for(;;);
