receiving one char on rs232 then rebooting
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Mon Jun 13, 2011 2:35 pm     Reply with quote
ok, i have something strange.
some code... works fine,
but after transmitting a serial character, the pic reboot
is there a solution to find out whats happening?
Carl
asmallri
Re: receiving one char on rs232 en rebooting
PostPosted: Mon Jun 13, 2011 2:49 pm     Reply with quote
Carl
You need to provide more information. What PIC family and what compiler. For example, if you are using a PIC24 / dsPIC then the problem could be as a WORD alignment problem causing a TRAP and not an RS232 issue.
Regards, Andrew
PostPosted: Mon Jun 13, 2011 2:50 pm     Reply with quote
Start by checking your code, and making sure you have not got an interrupt enabled, without an interrupt handler present. This _will_ cause the code to crash to an early memory location, and possibly behave as if the chip had reset....
Then add code right at the start of your main to read 'restart_cause', and put the value this returns out latter - on a port as a bit pattern perhaps. Have the code setup so it stops if this is _not_ a power on reset.
Hence code should run once, sending the byte to cause a problem, then on the restart, the 'cause' will become available for you to read with a meter/scope on the bit pattern. Look this up, and you may have a clue what is going on.
Compiler version?. Chip?. Small test program that shows the problem. All needed for us to help.
dorinjj
dsPIC33FJ64GP202 - INT_RDA problem
PostPosted: Thu Jun 30, 2011 8:36 am     Reply with quote
Hi, I have a problem with dsPIC33FJ64GP202 with UART Receive Interrupt (INT_RDA) and I don't know why.
The compiler version is 4.104.
I want to send at TX pin data that come from RX pin.
I made this simple program, but when I powered on the mcu, I received only one or two times this character "*" and after that if I want to send a character to mcu, nothing is happening.
Thank You.
#include <33FJ64GP202.h>
#device *=16
#fuses NOJTAG,NOWDT,FRC_PLL,OSCIO
#use delay(clock=80000000, type=internal)
#pin_select U1TX=pin_B0
#pin_select U1RX=pin_B1
#use rs232(baud=9600, UART1)
static unsigned int8 data_received;
void mcu_setup(void){
setup_oscillator(OSC_INTERNAL,80000000);
SETUP_WDT(WDT_OFF);
setup_uart(9600);
enable_interrupts(INT_RDA);
void main(){
mcu_setup();
SET_TRIS_a(0x0000);
SET_TRIS_b(0x0000);
output_a(0xffff); // this has no influence
output_b(0xffff); // this has no influence
     while(1){
     #asm
     nop
     #endasm
#int_rda
void receive_data(void){
   printf("*");
   data_received=getch();
   printf(data_received);
arunb
RE:
PostPosted: Tue Jul 05, 2011 2:32 am     Reply with quote
Don't put the printf() statements inside the interrupt handler. Instead set a flag inside the interrupt handler, check to see if the flag is set in the main loop, do the printing then clear the flag.
It is usual practice to do memory intensive jobs outside the ISR. The code inside the ISR should be kept as minimum as possible.
In your case the ISR will contain the statement to set the flag, and another statement to receive the character.
Hope this helps you..
thanks
a
PostPosted: Tue Jul 05, 2011 4:44 am     Reply with quote
The code as written, _will_ hang the UART.
Problem is that for each single character received, the code sends two. After only a couple of charcaters, the output buffer will be full, so the printf, then _waits_ for the character to transmit. Meanwhile, other characters arriving, will have now overflowed the input buffer, resulting in this being in an error state, and the UART is hung.....
Add the keyword 'ERRORS' to the RS232 setup. This will add code to clear the hang. Data will still be lost, but at least things will keep working....
If you want to send two characters back, you need to be using an interrupt driven transmit, as well as the receive, and have a software buffer large enough to handle the extra characters, and/or flow control (pause the transmission when the buffer approaches full).
dorinjj
PostPosted: Tue Jul 05, 2011 3:59 pm     Reply with quote
I had modified a bit the program after "arunb" advice and now I can receive data from mcu.
However, I can't use printf() function, for example: if I use printf() (with "ERRORS" in #use rs232...) and If I send any text to the mcu with 10 chars for example, I receive totally something else with a small number of chars, so I must use putc() function.
#device *=16
#use rs232(baud=9600, UART1, ERRORS) // use ERRORS
static int1 rx_flag=0;
SETUP_WDT(WDT_OFF);
setup_uart(9600);
void main(){
mcu_setup();
SET_TRIS_a(0x0000);
//SET_TRIS_b(0b0000000000000010); // RX pin -> input
SET_TRIS_b(0x0000); // this has no effect on RX pin
output_a(0xffff);
output_b(0b1111111111111100);
output_float(pin_B1);  // RX pin must "float"
//output_float(pin_B0); // TX is not necessary to "float"
     while(1){
        if(rx_flag==1){
           putc(data_received);
           //printf(data_received); //doesn't work
           rx_flag=0;
#int_rda
   rx_flag=1;
   //putc('*'); // if I use this uart will hang
   //putc(data_received); // I can use this instead "rx_flag"
//Conclusion:
//If I use UART, I should make RX pin "to float"
PostPosted: Tue Jul 05, 2011 4:30 pm     Reply with quote
ISR (Interrupt Service Routines) are supposed to be very, very short !
Set a 'flag' that 'you got data' then exit, your 'main' routine will then see that the 'flag' has been set, take appropriate action and reset the 'flag'.
hth
PostPosted: Tue Jul 05, 2011 4:38 pm     Reply with quote
Another option is to use a global variable that you assign from getc(). In
the main loop, if a character has arrived it will be non-zero. Save the
character then zero the variable and wait for it to be non-zero again.
The downside is you will have to check this often to keep from losing
characters. The best bet is to use the CCS example ex-sisr.c for a guide.
