rs232 at baud 2 to 5
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Jun 10, 2011 1:23 am     Reply with quote
Wondering if anyone has any code for a software uart running at a baud rate of 2 to 5. It seems the CCS in-built functions only work at 6 and above! I only need transmit. Or is there a work around before I write my own :-(
PostPosted: Fri Jun 10, 2011 4:21 am     Reply with quote
I'm surprised the CCS functions allow rates this low. At 2 baud, you are talking 5 seconds to send a single character.
Best way probably, something like (depending on your master clock):
#include <16F877A.h>
#device *=16
#device adc=16
#FUSES NOWDT, HS, PUT, NOLVP
#define TXBUFFSIZE (32)
char RSTXbuffer[TXBUFFSIZE]; //Make large enough for your longest message.....
int8 buffer_in=0,buffer_out=0;
//Buffer handling tests and code
int8 btemp;
#define isempty(buff,in,out,size) (in==out)
#define hasdata(buff,in,out,size) (!(in==out))
#define isfull(buff,in,out,size) (((in+1)&(size-1))==out)
#define tobuff(buff,in,out,size,chr) { buff[in]=chr;\
   in=((in+1) & (size-1));\
   if (in==out) out=((out+1) & (size-1));\
#define frombuff(buff,in,out,size) (btemp=buff[out],\
   out=(out+1) & (size-1), \
   btemp)
#define clrbuff(buff,in,out,size) {in=0;\
   out=0;}
#define TICKS_PER_BAUD (124) //Change as required
#define TXPIN (PIN_A0) //Change as required
void bputc(char chr) {
  tobuff(RSTXbuffer,buffer_in,buffer_out,TXBUFFSIZE,chr);
//Tick routine - remember if the TICKS_PER_BAUD, goes over 255, to change ctr
//to an int16
#INT_TIMER2
void tick(void) {
  static int8 ctr;
  static int8 working;
  static int8 bitno;
  static int1 sending=FALSE;
  if (sending) {
     //Code to actually send byte
     //Wait for the counter to get to zero
     if (--ctr == 0) {
        //Now send the next bit
        bitno++;
        if (bitno<8) {
           output_bit(TXPIN,working & 1);
           working/=2;
           ctr=TICKS_PER_BAUD;
        else {
           //Stop bit or finished
           if (bitno==8) {
              output_high(TXPIN);
              ctr=TICKS_PER_BAUD;
           else {
              sending=FALSE; //Finished byte
  else {
     if (hasdata(RSTXbuff,buffer_in,buffer_out,TXBUFFSIZE)) {
        //Here not s3ending, and a byte is in the output buffer
        working=frombuff(RSTXbuffer,buffer_in,buffer_out,TXBUFFSIZE); //Get character
        sending=TRUE;
        bitno=0;
        ctr=TICKS_PER_BAUD;
        output_low(TXPIN);
void main(void) {
  setup_timer_2(T2_DIV_BY_16,251,10);      //806 us overflow, 8.0 ms interrupt
  clrbuff(RSTXbuff,buffer_in,buffer_out,TXBUFFSIZE);
  //Gives 124 calls per bit
  //Then to send:
  printf(bputc,"Test message\n");
  do {
  } while (TRUE);
No guarantees, but it then allows your main code to be doing other things while sending data at this ultra-slow rate....
Will Reeve
PostPosted: Fri Jun 10, 2011 7:31 am     Reply with quote
Thanks. That looks a great foundation. Yes slow rate, slow transmission process! I wish I could tell you more!
Keep well,
Will
PostPosted: Fri Jun 10, 2011 8:32 am     Reply with quote
Very low rates, are common, but not quite this low!.
However depending on the exact setup, given just how long it'll take to send a message, and hence the difficulty of asking for a repeat if something goes wrong, I'd suggest you look at hamming codes. Adding 50% to the transmitted data length, would allow detection of two bit errors, and correction of any single bit error.
