deep sleep problems with PIC18F46J11
magic_mauve
PostPosted: Tue Apr 05, 2011 7:41 am     Reply with quote
I can't seem to wake up from deep sleep using the RTCC alarm on the PIC18F46J11. ( I also tried and failed with the deep sleep watchdog too). Here is my code. I would be really grateful if someone could spot where I am going wrong. I am fairly new to programming with PICS. The alarm works fine when I go to normal (PRI-IDLE) sleep.
#include <18F46J11.h>            // CCS standard header for PICC 18F46J11
#define CPU_CLK      4000000
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use DELAY(crystal=4000000)
#byte WDTCON = 0xFC0
#byte DSCONH = 0xF4D
#byte DSCONL = 0xF4C
#byte RTCCFG = 0xF3F
#byte DSWAKEH= 0xF4b
#byte DSWAKEL= 0xF4a
#byte OSCCON = 0xFD3
#bit IDLEN=OSCCON.7      // used to set IDLE low-power mode
#bit DSEN = DSCONH.7     // used to set deep sleep
#bit REGSLP =WDTCON.7
#bit RELEASE = DSCONL.0
#bit RTCSYNC = RTCCFG.4
#bit DS_WAKEUP_BIT = WDTCON.3     // bit that detects wake up from deep sleep
#include <string.h>
#include <stdlib.h>
/************************************************** 4.0 Macro Constant Definitions *************************************************************
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOWDT                    //No Watch Dog Timer, control placed on SWDTEN bit
#FUSES NOIESO                     //two speed start up disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOLPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOT1DIG
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH(>10mhz for PCD)
#FUSES WDT16                    //
#FUSES DSWDT8192                // 8.5 sec deep sleep watchdog
#FUSES DSWDT                    // enable deep sleep watchdog timer
#FUSES NODSBOR                  // disable deep sleep brown-out
#FUSES RTCOSC_INT               // use INTRC as ref clock for RTCC
#FUSES DSWDTOSC_INT             // use INTRC as ref clock for deep sleep wdt
#FUSES NOIOL1WAY                //No reconfiguration of peripheral pins allowed
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#PIN_SELECT U2TX=PIN_B4
#PIN_SELECT U2RX=PIN_B5
#use rs232(UART2, baud=9600, ERRORS, STREAM=PC)
#define TRISA_VAL   0x02
#define TRISB_VAL   0x2F
#define TRISD_VAL   0x20
#define TRISE_VAL   0x00
byte alarm=0;
//interrupt handling routing for Real-Time Clock
#INT_RTC
void Send_Time_RTC(void)
   alarm++;
  rtc_time_t SetTime;
  rtc_time_t AlarmTime;
  setup_oscillator(OSC_NORMAL|OSC_PLL_OFF);
  set_tris_a(TRISA_VAL);
  set_tris_b(TRISB_VAL);
  set_tris_d(TRISD_VAL);
  set_tris_e(TRISE_VAL);
  //delay to allow power to stabilise
  fprintf(PC,"\r\n\r\nHello World: Booting Up\r\n");
   switch ( restart_cause() )
      case WDT_TIMEOUT:
         fprintf(PC,"\r\nRestarted processor because of watchdog timeout\r\n");
      case NORMAL_POWER_UP:
         fprintf(PC,"\r\nNormal power up!\r\n");
      case WDT_FROM_SLEEP:
         fprintf(PC,"\r\nrestart caused by watchdog from sleep\r\n");
      default:
         fprintf(PC,"\r\nunknown restart reason\r\n");
   // check if reset is from deep sleep
   if (DS_WAKEUP_BIT == 1)
     // wake up from deep sleep
     fprintf(PC,"Deep Sleep Wake up");
     // determine cause of wake up
     fprintf(PC," cause H %x\r\n", DSWAKEH);
     fprintf(PC," cause L %x (watchdog is  bit 4 set) \r\n", DSWAKEL);
     DS_WAKEUP_BIT = 0; // clear the deep sleep bit
     fprintf(PC," Brown Out check %x\r\n", DSCONL);
     // clear the release bit
     RELEASE = 0;
     fprintf(PC,"         wait 2 secs  \r\n");
     delay_ms(2000);
     fprintf(PC,"Send to deep sleep and set up alarm for wake up at 10 secs\r\n");
     // set up rtc
     SetTime.tm_year = 11;
     SetTime.tm_mon  = 3;
     SetTime.tm_mday = 9;
     SetTime.tm_wday = 3;
     SetTime.tm_hour = 11;
     SetTime.tm_min  = 47;
     SetTime.tm_sec  = 0;
     // set alarm time
     AlarmTime.tm_year = 11;
     AlarmTime.tm_mon  = 3;
     AlarmTime.tm_mday = 9;
     AlarmTime.tm_wday = 3;
     AlarmTime.tm_hour = 11;
     AlarmTime.tm_min  = 47;
     AlarmTime.tm_sec  = 15;
     rtc_write(&SetTime);
     setup_rtc(RTC_ENABLE,0);
     setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_10_SECONDS, 0xFF);
     rtc_alarm_write(&AlarmTime);
     enable_interrupts(INT_RTC);
     REGSLP = 1; // enable low-power operation in sleep mode
     IDLEN = 0;
     while (RTCSYNC > 0) ;
     DSEN = 1;
     sleep();
     fprintf(PC,"The end\r\n");
PostPosted: Tue Apr 05, 2011 4:23 pm     Reply with quote
What's your CCS compiler version ?
magic_mauve
PostPosted: Wed Apr 06, 2011 2:40 am     Reply with quote
It is version 4.100.
PostPosted: Fri Apr 08, 2011 2:54 pm     Reply with quote
Here's a test program for RTCC alarm wake-up from Deep Sleep.
I don't have your exact PIC, but I have the 18F24J11 which is in
the same family.
I have a 32.768 KHz watch crystal installed on the Timer1 oscillator pins
on the PIC. I didn't have the 12 pf capacitors recommended by the PIC
data sheet for use with that crystal, so I used 22 pf caps and it still worked.
Here's the output from the program shown below. The PIC wakes up
every 5 seconds, which is correct. I timed it with a stop-watch.
It's working. I tested this with compiler versions 4.100 and 4.119.
Start-up by some other method.
Going to sleep.
Wake-up by RTCC alarm from Deep Sleep.
Going to sleep.
Going to sleep.
Going to sleep.
I didn't try to test the "Context save" feature for Deep Sleep mode.
(And I don't really want to work on it). I just wanted to show how to use
the RTCC alarm to wake-up from Deep Sleep. Here is the test program:
#include <18F24J11.h>
#fuses HS,NOWDT,RTCOSC_T1  // RTCC uses Timer1 osc with 32.768 KHz xtal
#use delay(crystal=20M)    // PIC uses 20 MHz crystal
#bit IDLEN =OSCCON.7      // Used to set IDLE low-power mode
#bit DSEN = DSCONH.7      // Used to set deep sleep
#bit DS_WAKEUP_BIT = WDTCON.3   // Bit that detects wake up from DS
#bit DSRTC = DSWAKEL.3
rtc_time_t SetTime;
rtc_time_t read_clock;
// Release the PIC's i/o pins for normal operation
// after waking up from Deep Sleep.  Important !
RELEASE = 0;
// Tell what caused us to start-up.
if((DS_WAKEUP_BIT == 1) && (DSRTC == 1))
   printf("\n\rWake-up by RTCC alarm from Deep Sleep.\n\r");
   printf("\n\rStart-up by some other method.\n\r");
// Set initial RTC date/time values in structure.
SetTime.tm_year = 0x11;
SetTime.tm_mon  = 3;
SetTime.tm_hour = 0x11;
SetTime.tm_min  = 0x47;
SetTime.tm_sec  = 0;
// Write that structure into the RTC hardware registers
// inside the 18F26J11.
// Set RTC alarm date/time.
AlarmTime.tm_year = 0x11;
AlarmTime.tm_hour = 0x11;
AlarmTime.tm_min  = 0x47;
AlarmTime.tm_sec  = 5;
      rtc_read(&read_clock);        //reads clock value from RTCC
      printf("\n\r%02u/%02u/20%02u %02u:%02u:%02u",read_clock.tm_mon,read_clock.tm_mday,read_clock.tm_year,read_clock.tm_hour,read_clock.tm_min,read_clock.tm_sec);
printf("Going to sleep.\n\r");
// Enable Deep Sleep mode.
IDLEN = 0;
while(RTCSYNC);
#asm       // Time-critical section must be in ASM
BSF DSEN
SLEEP
#endasm
// We should never reach the following line after a
// Deep Sleep RTCC wake-up, because it does a reset
// intentionally. It re-starts code execution at main().
printf("Woke-up from sleep ! \r\n");
Edit:
Removed the line for 'enable_interrupts(INT_RTCC);' that was placed
after the printf for "going to sleep". It's not necessary.
magic_mauve
PostPosted: Sun Apr 10, 2011 2:30 pm     Reply with quote
Thank you PCM programmer! I am delighted to say thanks to you I have got it working now. Much appreciated. Very Happy
PostPosted: Sun Apr 10, 2011 2:40 pm     Reply with quote
After you posted, I reviewed the code and noticed that I had left in a line
from your program, where you enabled INT_RTCC interrupts. That's not
needed for my demo program so I edited the code and removed it.
I tested it just now, and the program runs fine without it.
magic_mauve
PostPosted: Sun Apr 10, 2011 2:57 pm     Reply with quote
Great. Thanks again.
heUAcyp
RTCC issue
PostPosted: Thu Jun 09, 2011 9:10 am     Reply with quote
Hi all,
Since it has been discussed here, I have a question on RTCC.
I set hour = 23 , min= 59 and sec=50 , just to make sure that it will automatically increment the day after 23:59:59. But apparently PIC re-starts counting from 20:00:00 and doesn't increment the day, I am posting the output on the hyperterminal:
03/09/2011 23:59:50
03/09/2011 23:59:52
03/09/2011 23:59:53
03/09/2011 23:59:54
03/09/2011 23:59:55
03/09/2011 23:59:56
03/09/2011 23:59:57
03/09/2011 23:59:58
03/09/2011 23:59:59
03/09/2011 20:00:00
03/09/2011 20:00:01
03/09/2011 20:00:02
03/09/2011 20:00:03
and the code I used:
#include <18F25J11.h>
#device ADC=10
#include <STDIO.H>
#include <stdlib.h>
#include <math.h>
#include <STRING.H>
#include <2408.c>
#fuses HS,NOWDT,NOPROTECT,RTCOSC_T1
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#byte INTCON = 0xFF2
#byte INTCON2 = 0xFF1
#bit IDLEN=OSCCON.7      // used to set IDLE low-power mode ( will be set to zero for both deep-sleep and sleep modes)
#bit DSEN = DSCONH.7     // used to set deep sleep (1 for deep-sleep)
#bit DSINT0 = DSWAKEH.0 // bit for INT0 interrupt - change detection
#bit INT0IE = INTCON.4
#bit INT0IF = INTCON.1
#bit INTEDG0 = INTCON2.6
int8 i ;
void EnterDeepSleep()
IDLEN = 0;
while(RTCSYNC);
BSF DSEN
SLEEP
NOP
#endasm
//disable_interrupts(GLOBAL);
rtc_time_t SetTime;
SetTime.tm_mon  = 3;
SetTime.tm_hour = 23;
SetTime.tm_min  = 59;
SetTime.tm_sec  = 49;
RELEASE = 0;   // Activate i/o pins
delay_ms(10);
printf("\n\r\n\r");
printf("DS_WAKEUP_BIT:  %x \n\r", DS_WAKEUP_BIT);
delay_ms(10);
printf("DS_WAKEUP_BIT:  %x \n\r", DSINT0);
delay_ms(10);
printf("DSWAKEH:  %x \n\r", DSWAKEH);
delay_ms(10);
printf("DSWAKEL:  %x \n\r", DSWAKEL);
delay_ms(10);
// Clear the wake-up source registers, regardless
// of what the PIC data sheet says.
DSWAKEL = 0;
DSWAKEH = 0;
// Look at the current state of the push-button switch.
// Based on that, set the edge that we expect to see next.
if(input(PIN_B0) == 1)   // If switch is high
ext_int_edge(H_TO_L); // Then expect a falling edge next
else                     // If switch is low
ext_int_edge(L_TO_H); // Then expect a rising edge next
clear_interrupt(INT_EXT);
enable_interrupts(INT_EXT);
delay_ms(10);
EnterDeepSleep() ;
printf("Should never get here\n\r");
while(true)
how this can be fixed? I have tried with different PIC's and same problem exists.
My compiler version is V4.095, I have tested with V4.085 and its not working.
Regards
PostPosted: Thu Jun 09, 2011 11:56 am     Reply with quote
It works OK with vs. 4.121:
03/09/2011 23:59:49
03/09/2011 23:59:49
03/09/2011 23:59:50
03/09/2011 23:59:51
03/09/2011 23:59:52
03/09/2011 23:59:53
03/09/2011 23:59:54
03/09/2011 23:59:55
03/09/2011 23:59:56
03/09/2011 23:59:57
03/09/2011 23:59:58
03/09/2011 23:59:59
03/10/2011 00:00:00
03/10/2011 00:00:01
03/10/2011 00:00:02
There's a bug in your compiler version, 4.095. I don't have time to look it
at it right now.
heUAcyp
PostPosted: Thu Jun 09, 2011 12:37 pm     Reply with quote
Thanks sir , easiest solution would be to get V 4.121
Regards
heUAcyp
Still not working
PostPosted: Fri Jun 17, 2011 10:49 am     Reply with quote
Sir, I have tried many times but RTCC is NOT incrementing while in deep sleep mode:
I am constantly checking registers, and I have fixed all the problems associated with that. RTCC is just not incrementing
With code given below. Initial output on hyperterminal is :
check hyperterminal
before the if loop DS_WAKEUP_BIT: 00
before the if loop DSWAKEH: 00
before the if loop DSWAKEL: 00
after the if loop DSWAKEH: 00
after the if loop DSWAKEL: 00
check if the registers are set DSWAKEH: 00
check if the registers set DSWAKEL: 00
When I close the switch(PIN B0 == 0 )
before the if loop DS_WAKEUP_BIT: 01
before the if loop DSWAKEH: 01
DS_WAKEUP_BIT: 01
Interrupt detected
DSWAKEH: 01
DSWAKEL: 00
Patch is on - DATE:9: 3: 11
TIME:12: 59: 49
sleeping now
DS_WAKEUP_BIT: 01
after the if loop DSWAKEH: 01
DS_WAKEUP_BIT: 01
Interrupt detected
DSWAKEH: 01
DSWAKEL: 00
Patch is off -- DATE:9. 3. 11
TIME:12: 59: 49
sleeping now
DS_WAKEUP_BIT: 01
The code I am using:
#device ADC=10
#include <STDIO.H>
#include <stdlib.h>
#include <math.h>
#include <STRING.H>
#include <2408.c>
#fuses HS,NOWDT,NOPROTECT, RTCOSC_T1
char buffer[160];
rtc_time_t SetTime;
int8 status ;
void InitTime()
/* !!!!! I cannot define it here as
it gives error in dateandtimeon() function)*/
//rtc_time_t SetTime;
//set_rtcc(RTCC_INTERNAL);
SetTime.tm_mon  = 3;
SetTime.tm_hour = 12;
IDLEN = 0;
while(RTCSYNC);
BSF DSEN
SLEEP
NOP
#endasm
void dateandtimeon()
rtc_read(&SetTime);
buffer="";
sprintf(buffer, "Patch is on - DATE:%d: %d: %d", SetTime.tm_mday, SetTime.tm_mon,SetTime.tm_year); printf("%s\n\r",buffer);
buffer="";
sprintf(buffer, "TIME:%d: %d: %d ",  SetTime.tm_hour, SetTime.tm_min, SetTime.tm_sec); printf("%s\n\r",buffer);
void dateandtimeoff()
rtc_read(&SetTime);
buffer="";
sprintf(buffer, "Patch is off -- DATE:%d. %d. %d", SetTime.tm_mday, SetTime.tm_mon,SetTime.tm_year); printf("%s\n\r",buffer);
buffer="";
sprintf(buffer, "TIME:%d: %d: %d ",  SetTime.tm_hour,SetTime.tm_min, SetTime.tm_sec); printf("%s\n\r",buffer);
void storetoMemory() {
if(status == 1)   // If switch is high
dateandtimeoff(); // Then expect a falling edge next
dateandtimeon();
delay_ms(10);
printf("sleeping now \n\r ") ;
delay_ms(10);
output_high(PIN_A2) ;
InitTime() ;
printf("check hyperterminal \n\r ") ;
delay_ms(10);
printf("before the if loop DS_WAKEUP_BIT:  %x \n\r", DSINT0);
delay_ms(10);
printf("before the if loop DSWAKEH:  %x \n\r", DSWAKEH);
delay_ms(10);
printf("before the if loop DSWAKEL:  %x \n\r", DSWAKEL);
delay_ms(10);
/*if loop to perform main task*/
if((DS_WAKEUP_BIT == 1) && (DSWAKEH == 1))
delay_ms(10);
delay_ms(10);
printf("Interrupt detected \n\r");
delay_ms(10);
delay_ms(10);
delay_ms(10);
storetoMemory() ;
delay_ms(200);
delay_ms(10);
printf("after the if loop DSWAKEH:  %x \n\r", DSWAKEH);
delay_ms(10);
printf("after the if loop DSWAKEL:  %x \n\r", DSWAKEL);
delay_ms(10);
DSWAKEL = 0;
DSWAKEH = 0;
printf("check if the registers are set DSWAKEH:  %x \n\r", DSWAKEH);
delay_ms(10);
printf("check if the registers set DSWAKEL:  %x \n\r", DSWAKEL);
delay_ms(10);
{  // If switch is high
status = 0 ;
status = 1 ;
delay_ms(10);
EnterDeepSleep() ;
while(true)
Compiler version is still V4.095 but I have ordered the V4.121 .
As you see in the lines:
TIME:12: 59: 49
and
TIME:12: 59: 49
RTCC is not working.
Please help.
Regards
heUAcyp
PostPosted: Fri Jun 17, 2011 1:45 pm     Reply with quote
Here is the simplified code,
Basically problem is the RTCC does not increment. Initially set values keeps repeating.
#device ADC=10
#include <STDIO.H>
#include <stdlib.h>
#include <math.h>
#include <STRING.H>
#include <2408.c>
char buffer[160];
rtc_time_t SetTime;
int8 status ;
void InitTime()
SetTime.tm_mon  = 3;
IDLEN = 0;
while(RTCSYNC);
BSF DSEN
SLEEP
NOP
#endasm
rtc_read(&SetTime);
buffer="";
sprintf(buffer, "ON_TIME:%d: %d: %d ",  SetTime.tm_hour, SetTime.tm_min, SetTime.tm_sec); printf("%s\n\r",buffer);
rtc_read(&SetTime);
buffer="";
sprintf(buffer, "OFF_TIME:%d: %d: %d ",  SetTime.tm_hour,SetTime.tm_min, SetTime.tm_sec); printf("%s\n\r",buffer);
InitTime() ;
delay_ms(10);
delay_ms(10);
delay_ms(10);
delay_ms(10);
dateandtimeon();
DSWAKEL = 0;
DSWAKEH = 0;
status = 0 ;
status = 1 ;
delay_ms(10);
EnterDeepSleep() ;
while(true)
And the output on hyperterminal when using switch at pin 21 (INT0) :
DS_WAKEUP_BIT: 01
DSWAKEH: 01
DSWAKEL: 00
ON_TIME:12: 59: 49
DS_WAKEUP_BIT: 01
DSWAKEH: 01
DSWAKEL: 00
OFF_TIME:12: 59: 49
dap20
PostPosted: Fri Jan 27, 2012 4:42 pm     Reply with quote
PCM programmer wrote:
while(RTCSYNC);
BSF DSEN
SLEEP
#endasm
You say you make it re-start code execution at main intentionally. How can I make it continue just after the sleep instruction and not go back to the main ?
thanks
PostPosted: Mon Jan 30, 2012 9:00 pm     Reply with quote
Read the 18F46J11 data sheet:
3.6.3 DEEP SLEEP WAKE-UP SOURCES
While in Deep Sleep mode, the device can be awakened
by a MCLR, POR, RTCC, INT0 I/O pin interrupt,
DSWDT or ULPWU event. After waking, the device performs
a POR
. When the device is released from Reset,
code execution will begin at the device’s Reset vector.
There is no option to resume running at the line in the program
after the Deep Sleep. It always does a Power-on-Reset.
