WildLife
| Problem sending command from 16F877 to GPRS modem |
Posted: Wed Jun 08, 2011 8:21 pm |
Hi guys, first post here
I'm trying to communicate my 16F877 with a GPRS modem (ADH8066 with the evaluation board from sparkfun).
I'm using the following code:
#include <16F877A.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GPRS,ERRORS)
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
char cmd_str[20];
byte bgetc()
byte c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
#int_rda
void serial_received()
int t;
buffer[next_in]=getc();
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
void init()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
output_high(GSM_ONKEY);
output_high(GSM_CTS);
output_high(GSM_DSR);
output_low(GSM_LED);
int startGSM()
delay_ms(200);
output_low(GSM_ONKEY);
delay_ms(2000);
delay_ms(300);
output_low(GSM_CTS);
output_low(GSM_DSR);
delay_ms(4000);
//ler ready!
return 1;
void testePrintGSM()
fprintf(GPRS,"AT\n");
int8 cont = 0;
unsigned char a;
init();
timeout(5);
output_high(GSM_LED);
startGSM();
timeout(15);
while(true)
// Searches for 'ady' from the word Ready witch means modem has reset
if (bkbhit)
a = bgetc();
if (a == 'a')
a = bgetc();
if (a == 'd')
a = bgetc();
if (a == 'y')
timeout(3);
testePrintGSM();
// Searches for OK, reply from the command fprintf(GRPS,"AT\n")
else if (a == 'O')
a = bgetc();
if (a == 'K')
delay_ms(50);
Sorry for the big code, anyways, I'm able to read from the modem the "Ready" reply, but I can't read the OK reply, so I assume I'm not being able to send the "AT\n" command. Any ideas?
BTW I've already tried fprintf, putc, and so on, with no luck :/
Thanks,
WildLife |
Posted: Wed Jun 08, 2011 9:13 pm |
| Quote: | fprintf(GPRS,"AT\n");
Your final character is a newline, but the modem expects a carriage
return, which is a \r. |
WildLife
Posted: Thu Jun 09, 2011 8:59 am |
| PCM programmer wrote: | | Quote: | fprintf(GPRS,"AT\n");
That might have saved me some hassle in the future, but still it isn't working :(
Any other thoughts?
Thanks |
