Measuring MIPS with Output instructions
mickent
PostPosted: Wed Jun 08, 2011 11:48 pm     Reply with quote
I need to know the MIPS that my PIC33 is running at because my DAC is running at half speed so I made a tight loop in main:
while 1,
output high;
output low;
This runs at 3.7 Mhz
Would this be 3 instructions so the MIPS is 11.1 MIPS?
Thanks, Mick
Mick
SherpaDoug
PostPosted: Thu Jun 09, 2011 5:37 am     Reply with quote
MIPS usually refers to machine or assembly instructions, not lines of C code. Look at your program .lst file to see how many assembly instructions are there.
mkent
PostPosted: Thu Jun 09, 2011 12:53 pm     Reply with quote
Thanks SherpaDoug,
This is the list file:
154:               // Main Code
155:                   while (1)
156:                  {
157:                  output_high(PIN_B13);
  0330  A9A2C9     bclr.b 0x02c9,#5
  0332  A8A2CD     bset.b 0x02cd,#5
158:                  output_low(PIN_B13);
  0334  A9A2C9     bclr.b 0x02c9,#5
  0336  A9A2CD     bclr.b 0x02cd,#5
159:               /*
160:                  MotorCntlLeft= 0xfff0;
161:                  MotorCntlRight = 0xfff0;
162:                  AuxCntlWord = 0xfff0;
163:
164:                  if(!input(PIN_B5))
165:                     {
166:                     Rover_Control_Xmit();
167:                     }
168:               */
169:                  }
  0338  37FFFB     bra 0x000330
  033A  37FFFF     bra 0x00033a
I'm still not sure how to count instructions? Does the "while" loop take clock cycles?
PostPosted: Thu Jun 09, 2011 1:15 pm     Reply with quote
How to use the MPLAB stopwatch feature to count instruction cycles:
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
PostPosted: Thu Jun 09, 2011 1:42 pm     Reply with quote
Just open up the databook for you PIC and go to the instruction set chapter. Every instruction will have the number of machine cycles it takes to executes. Bit clear, bit set are 1 cycle each, branches are 2 cycles.
So in your case 6 machine cycles. How long that takes depends on the crystal running the PIC and any divider you might have chosen...
mkent
PostPosted: Thu Jun 09, 2011 3:06 pm     Reply with quote
Thanks for the replies.
PCM the stopwatch won't work above 20 Mhz.
My only question now is about clock cycles vs instruction cycles. The PIC33 has 2 clock cycles for each instruction cycle.
So 6 x 3.68 Mhz = 22.08 Mhz This is the MIPS (Fcy) that I expect. My clock is 44.2 Mhz.
So why does the DAC run at half speed?
Fvco = 176 Mhz,
Aux clock divider is 8 so Aclk = 22 Mhz / 256 = 86 Khz and I measure 43 Khz.
I made it work by reducing my sine array from 72 values to 36 but this bugs me.
Any ideas?
Mick
PostPosted: Thu Jun 09, 2011 3:17 pm     Reply with quote
The stopwatch works at the frequency you put in as the PIC operating frequency. Defaults to 20MHz, but runs happily at 100M+...
Look at the data sheet. Oscillator section. Where does 'Fp' come from (peripheral clock used by stuff like the ADC)?. It is _not_Fosc....
mkent
PostPosted: Thu Jun 09, 2011 4:17 pm     Reply with quote
Ttelmah, I get this error when I try to use the stopwatch with a MIPS of 22 Mhz.
ADC-W0007: Cannot meet full accuracy with RC clock source and Frequency > 20Mhz
I am going to start a new thread to discuss my DAC problem for the sake of the search engine.
Mick
PostPosted: Fri Jun 10, 2011 4:29 am     Reply with quote
Look carefully at your fuse settings. Just ran MPLAB up with a PIC33 selected, and clock rate of 120MHz from the internal oscillator/PLL, and no such complaint.
Happily took 0.01667uSec for an instruction....
bkamen
PostPosted: Fri Jun 10, 2011 10:27 am     Reply with quote
mkent wrote:
Thanks SherpaDoug,
154:               // Main Code
155:                   while (1)
156:                  {
159:               /*
163:
165:                     {
167:                     }
168:               */
169:                  }
If you use #use fast_io, you can eliminate the direction register settings in your loop, BUT YOU NEED TO MAKE SURE to do it before the while loop starts.
And yes, the while loop is essentially the BRA 0x000330 command that you must have to keep the loop going.
The BRA following is essentially to keep the PIC in a known state (rather than run off into memory) in case you DIDN'T have something in main to keep control of the process.
-Ben
eoinoc
PostPosted: Mon Jun 13, 2011 6:17 am     Reply with quote
To measure you instruction speed use the repeat instruction
while(true)
#asm
repeat #0x3fff
btg .....
#endasm
This will give you a good burst of pin toggle at your instruction speed, of course there will be a small glitch at the end of the while true loop.
