Tx only RS232
JerryR
Tx only RS232
PostPosted: Wed Jun 08, 2011 5:57 am     Reply with quote
This should be a well documented topic, but I can't seem to find an answer after a somewhat complete search.
I need only to perform transmit RS232 functions. My hardware supports using the hardware tx USART pin on a 18FL14K22. Using either hardware or software USART function, can I implement only tx functions and leave the rx pin "released" for use as a discrete I-O line?
Thanks group
PostPosted: Wed Jun 08, 2011 8:16 am     Reply with quote
Declare both in the #use rs232 statement (if you don't, the code won't select the hardware UART). Then the compiler only actually 'generates' the receive code, when it is used, so this is not a problem. Then just use the pin as normal.
It is slightly harder to do the opposite way round (hardware receive, with the TX pin used for normal I/O), with you having to turn off the TXEN bit in the UART, or this overrides the normal pin functions, but for the receive pin, you can read/write the pin normally, even if the UART is enabled.
JerryR
PostPosted: Wed Jun 08, 2011 8:24 am     Reply with quote
Ttelmah:
Thanks for the reply. I'll double-check the code and operation, but attempted this using hardware EUSART pins and couldn't control the receive pin (RB5). You're right, it looks like your method should work fine.
PostPosted: Wed Jun 08, 2011 9:21 am     Reply with quote
Yes, just don't assign a pin in the use rs232(....) function.
PostPosted: Wed Jun 08, 2011 11:44 am     Reply with quote
Temtronic,
What you propose, won't work.
Here's the normal declaration with both hardware pins for this PIC:
#include <18LF14K22.h>
#fuses HS,NOWDT
#use delay(clock=20M)
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
putc(0x55);
The program above produces the code below, which writes to TXREG.
So it's using the hardware UART for Tx.
...... #use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
0004:  BTFSS  PIR1.TXIF
0006:  BRA    0004
0008:  MOVWF  TXREG
000A:  GOTO   0040 (RETURN)
....... putc(0x55);
003C:  MOVLW  55
003E:  BRA    0004
Here is a revised program based on your proposal to leave out the Rx pin:
#fuses HS,NOWDT
#use rs232(baud=9600, xmit=PIN_B7)
putc(0x55);
Here's the generated code for the program above. It's clearly not using
the hardware UART. It's manually "bit banging" the transmitted byte.
That's not what the O.P. wants.
.................... #use rs232(baud=9600, xmit=PIN_B7)
0004:  BCF    TRISB.TRISB7
0006:  BCF    LATB.LATB7
0008:  MOVLW  08   // Send 8 data bits
000A:  MOVWF  @01
000C:  BRA    000E
000E:  NOP
0010:  BSF    01.7
0012:  BRA    0030
0014:  BCF    01.7
0016:  RRCF   ??65535,F
0018:  BTFSC  STATUS.C
001A:  BSF    LATB.LATB7  // Set or clear Pin B7, based on the
001C:  BTFSS  STATUS.C  // current bit value that is being sent.
001E:  BCF    LATB.LATB7
0020:  BSF    01.6
0022:  BRA    0030
0024:  BCF    01.6
0026:  DECFSZ @01,F
0028:  BRA    0016
002A:  BRA    002C
002C:  NOP
0042:  GOTO   006A (RETURN)
.................... putc(0x55);
0064:  MOVLW  55
0066:  MOVWF  ??65535
0068:  BRA    0004
PostPosted: Wed Jun 08, 2011 2:35 pm     Reply with quote
The OP's second sentence led me to believe either hard or soft was 'ok' to implement but I could have been thinking wrong....
...it's about 40C here today and I'm not used to it ,yet.
