AD7705 reading problems
assaad
PostPosted: Mon Jun 06, 2011 9:35 am     Reply with quote
Hello everyone
I have connected REF+ to 2.5V
REF- to gnd
AN2- to gnd
Then on AN2+ I put voltage from 0 to 2.5 that through a POT.
So when the voltage on AN2+ is 2.5v I should get a reading of 0xFFFF. But I get about 0x5555, which is it 0xffff/3
Do I have anything wrong with the connections?
My setting of ad7705 is
setup_adc_device( ADC_SELF, ADC_GAIN_1, ADC_UNIPOLAR, ADC_50);
Thank you
PostPosted: Mon Jun 06, 2011 9:46 am     Reply with quote
Tell us a lot more.
What PIC are you using?.
What connections for DRDY, DO, DI, RESET, CS and CLK?.
You have the required crystal?.
You are initialising the lines as in adc_init, except for the change to unipolar?.
assaad
PostPosted: Tue Jun 07, 2011 1:16 am     Reply with quote
Thank you Ttelmah
The problem is solved.
Before using this setup, I should choose the correct channel in the communication register.
:D
