PIC87J50 and USB(SOLVED)
Jody
PostPosted: Mon May 30, 2011 4:01 am     Reply with quote
Forgot the VUSB connection!!!!
FUSES:
#include <18F87J50.h>
#device ICD=TRUE
#device adc=16
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES PLL12                     //Divide By 12(48MHz oscillator input)
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOCPUDIV
#FUSES NOPROTECT
#FUSES HSPLL
#FUSES NOFCMEN
#FUSES NOIESO
#FUSES NOEASHFT
#FUSES MSSPMSK7
#use delay(clock=48000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=ID20)
I had the CDC code running on a PIC18F4550.. and now I want to get it running at a PIC87J50...
But I am missing something....
I think I messed up the fuse settings... (PIC Wizard isn't helping much)
What I have:
Compiler version: 4.119
Fuses:
#device ICD=TRUE
#device adc=16
#FUSES ECPLL
#FUSES NOCPUDIV
and in mine code I enable the PLLEN:
#include <main.h>
#include <stdlib.h>
#include <string.h>
#include <input.c>
#include <M95160SPI.c>
#include <LCD_CCS.c>
#include <DS1302SPI.c>
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
#define SLOT         pin_H3   //Relais uitgang 1
#define START         pin_H6   //Digitale I/O bit0
#define LICHTSLUIS0   pin_H7   //Digitale I/O bit1
#define LICHTSLUIS1   pin_H5   //Digitale I/O bit2
int              string_ready            = 0;
signed int      next_in               = 0;
char            string[20];
char            string_lengte[8];
char            string_papagaai_teller[4];
char            RFID[5];
int16           addres                  = 0;
int8            teller                = 0;
int8            papagaai_teller         = 0;
int8            papa_teller            = 0;
int8            first                  = 1;
int8            lengte_string         = 0;
int8            i                     = 0;
int8            hr                     = 0;
int8            min                     = 0;
int8             sec                     = 0;
int8          data_eeprom            = 0;
#byte OSCTUNE = 0xF9B
#bit PLLEN = OSCTUNE.6
char   string1[6]    = "C820\0";//papagaainummer
#USE SPI (MASTER, SPI2, MODE=0, BITS=8, STREAM=SPI_2, MSB_FIRST)
#int_RDA
void  RDA_isr(void)
 string[next_in]=fgetc(ID20);
  if((string[next_in] == 0x0D) & (next_in > 1))   //Einde string
    string_ready = 1;
    string[next_in+1] = '\0';
   next_in = 0;
  next_in=(next_in+1);
  if(next_in > 20) next_in = 0;
   int8 data;
    int8 wrote;
    int16 addr;
    int16 errors = 0;
   setup_timer_1(T1_DISABLED);
      setup_timer_3(T3_INTERNAL|T3_DIV_BY_1);
   setup_spi2(SPI_MASTER|SPI_XMIT_L_TO_H|SPI_SAMPLE_AT_MIDDLE|SPI_CLK_DIV_16);// test
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
    PLLEN = 1;    // Enable PLL
   delay_ms(50);
   usb_cdc_init();
   usb_init();
     init_ext_eeprom();
      delay_ms(50);
      output_low(SLOT);// van het slot af...
   lcd_gotoxy(1,1);
    printf(lcd_putc, "Papagaaiendeur");
  for(teller = 0; teller < 45; teller++)
    string[teller] = ' ';
  next_in = 0;
       usb_task();
       if (usb_enumerated())
   lcd_gotoxy(1,1);
   printf(lcd_putc, "USB enumerated!");
         if(string_ready == 1)
            printf(usb_cdc_putc,"string = ");
            printf(usb_cdc_putc,string);
            lengte_string = strlen(string);//lengte van de ontvangen string
            itoa(lengte_string, 10, string_lengte);// omzetten naar een string
            printf(usb_cdc_putc,string_lengte);// afbeelden
            printf(usb_cdc_putc,"\n");
            RFID[0] = string[(lengte_string-5)];
            RFID[1] = string[(lengte_string-4)];
            RFID[2] = string[(lengte_string-3)];
            RFID[3] = string[(lengte_string-2)];
            RFID[4] = '\0';
            printf(usb_cdc_putc,"RFID = ");
            printf(usb_cdc_putc,RFID);
              string_ready    = 0;
              next_in       = 0;
            lengte_string    = 0;
              for(teller = 0; teller < 20; teller++)
               if((strcmp(RFID, string1))==0)
                    output_high(SLOT);// deur open
               if(input(LICHTSLUIS0))// deur open gedaan
                  papagaai_teller = papagaai_teller + 1;
                  rtc_get_time(hr,min,sec);
                  write_ext_eeprom(addres,hr);addres++;
                  write_ext_eeprom(addres,min);addres++;
                  write_ext_eeprom(addres,sec);addres++;
                  write_ext_eeprom(addres,papagaai_teller);addres++;
                  delay_ms(50);
                  papa_teller   = read_ext_eeprom(0x000);
                  itoa(papa_teller, 10, string_papagaai_teller);// omzetten naar een string
                  printf(usb_cdc_putc,"papagaai_teller_eeprom = ");
                  printf(usb_cdc_putc,string_papagaai_teller);
                  first = 0;
anybody any ideas?????
Regards,
Jody
PostPosted: Mon May 30, 2011 7:59 am     Reply with quote
Is this solved?.
Thread title says so.
I have to ask 'why' you are using 48MHz?. Unless it is available elsewhere for some reason, you get less RF problems, and lower power consumption, running off a slower clock.
However with 48MHz, the combination you are trying to use is 'over complex'.
You have 48MHz, so don't need the PLL.
EC
FOSC2=1
PLLEN=0
FSEN=1
gives 48MHz to the USB.
Then CPUDIV1, and primary clock source enabled, gives 48MHz to the CPU.
You are unnecessarily taking 48MHz, dividing it by 12, multiplying by 24, and then dividing by 2. All extra power that is not needed.....
Jody
PostPosted: Mon May 30, 2011 8:03 am     Reply with quote
@Ttelmah,
You are right... it is a overkill and not charming to do this, this way.
And I will change it like the way you sugest... but the problem was that I can't connect to the USB ... and that is solved.
Thanks for thinking with me.
Regards,
Jody
