Integer expression to boolean Operator !!
ejeuler
PostPosted: Wed May 18, 2011 4:27 pm     Reply with quote
Hi All,
I've found examples of CCS C code using a "!!" operator, and comments indicating this converts an integer expression to boolean representation. I can find no references to this operator in my PCM compiler manual, older and newer CCS compiler manuals, Nigel Gardner's PIC Micro MCU C book, or searches in this forum or Google. Can someone please point me to where this operator is documented?
Thanks much!
ejeuler
dyeatman
PostPosted: Wed May 18, 2011 5:14 pm     Reply with quote
PostPosted: Wed May 18, 2011 7:24 pm     Reply with quote
Here is another forum thread that discuss the double-not:
http://stackoverflow.com/questions/248693/double-negation-in-c-code
ejeuler
PostPosted: Wed May 18, 2011 7:46 pm     Reply with quote
Thanks PCM programmer....
That link had some excellent discussion points/suggestions regarding integer/boolean conversions.
Thank you for taking the time to share this info!
ejeuler
PostPosted: Wed May 18, 2011 11:06 pm     Reply with quote
By C specification, integer operands can be used in a boolean expression. So the construct would be pretty useless. The discussion is referring to reasons as avoiding warnings with some compilers, or is speculating that if might serve a purpose somehow.
With CCS, I remember cases, at least with V3.xxx compilers, where the construct would help as bug workaround. A logical "&&" of int1 operands had been partly carried out as a & of the respective memory bytes and a bitmask, evaluating always false.
