jorsang2
| Help PWM in PIC16F684 |
Posted: Thu May 12, 2011 8:51 am |
Hi !
I have a problem with PIC16F684.
I would like to activate and see PWM in Proteus, but it doesn't work.
This is the code (partial code) :
#include <16F684.h>
#device adc=10
#FUSES WDT
#FUSES HS
#FUSES NOCPD
#FUSES NOPROTECT
#FUSES PUT
#FUSES BROWNOUT
#use delay(crystal=20000000)
restart_wdt();
set_timer0(1); // poner el timer0 a 1
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
setup_timer_0(T0_EXT_L_TO_H|T0_DIV_1);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_wdt(WDT_2304MS);
setup_timer_2(T2_DIV_BY_1,100,1); // Fpwm=50 kHz
setup_ccp1(CCP_PWM);
set_pwm1_duty(50);
restart_wdt();
set_timer0(1);
for (;;)
set_pwm1_duty(30);
restart_wdt();
set_timer0(1);
delay_us(800);
Please, could someone help me?
This code is now working (in proteus) in others PICs. I don't know why is not working with this PIC, I think maybe the fault is the simulator ...
Thanks in advance  |
Posted: Thu May 12, 2011 1:23 pm |
Always post your compiler version. Your version may have bugs.
If you post your version, then we (forum members) can look for
bugs in the ASM code. |
Posted: Thu May 12, 2011 2:53 pm |
Proteus, like all other simulators, is FULL of bugs.....
Get real PICs,wire them up and test in the real world.
You'll be a LOT happier !! |
jorsang2
Posted: Fri May 13, 2011 3:22 am |
| CCS PCM C Compiler, Version 4.104, 5967 |
