Byte error rate 10% with SPI
Goto page 1, 2  Next
lglenat
PostPosted: Sun May 08, 2011 12:35 pm     Reply with quote
Hi !
I'm trying to use SPI communication between a master and a slave, both PIC18F2523.
I think I'm doing that right, but when I compare the byte returned by the slave after a request of the master (using SPI twice), I get 5 to 15% of wrong bytes, depending on the different delays I chose between the different spi_read, spi_write calls, and other parameters (see after the code).
Here is my code :
MASTER
#include <18F2523.h>
#FUSES INTRC_IO, NOWDT, NOPROTECT, NOLVP
#use delay(clock=8M)
#byte SSPBUF = 0xFC9
#define SSBAL PIN_A3
long a=0,b=0,i=0;
//setup_timer_2(T2_DIV_BY_16,3,1);
// Initialize the hardware SSP for SPI Master mode.
//setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_T2);
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
output_high(SSBAL);  // Initial Slave Select to a high level
delay_us(100);
a++;
output_low(SSBAL);
delay_us(50);
spi_write(0b10101010);  // Send command to slave
output_high(SSBAL);
delay_us(10);  // Give slave some time to respond
output_low(SSBAL);
delay_us(50);
result = spi_read(0);// Read response from slave
output_high(SSBAL);
if (result==0b11001100)
       b++;
         i++;
SLAVE
long a=0,b=0,c=0;
int8 command;
#int_ssp
void ssp_isr(void)
disable_interrupts(INT_SSP);
a++;
command = SSPBUF;
if (command==0b10101010)
   b++;
   SSPBUF = 0b11001100;
   c++;
   SSPBUF=0;
enable_interrupts(INT_SSP);
clear_interrupt(INT_SSP);
// Initialize the hardware SSP for SPI Slave mode 0.
setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_XMIT_L_TO_H);
// Enable interrupts for the SPI slave.co
Maybe you can give me your opinion on the followings things, because I don't what can be the source of my problem :
- I'm using the internal oscillator (8M).
- If I use SPI_CLK_T2 as parameter in setup_spi, I get worse results than using SPI_CLK_DIV_16 (or 64), and the error rate depends also on the parameters of the timer2.
- if I don't add delay_us(50) after putting low the SS pin, the result is worse.
- the master seems to receive the byte 0 when it receives a wrong byte, and only 0, as he could not communicate with the slave. Maybe there is a problem of timing...
Thank you for your help !
Lucas (I'm french)
PostPosted: Sun May 08, 2011 2:39 pm     Reply with quote
Two issues..
1) master enables global interrupts but no ISRs are defined. Bad practice to enable without ANY ISRs....
2) internal oscillator is NOT a crystal, so check the datasheet for accuracy vs. operating voltage. Also the master could be say 8.001 and the slave 7.998 Mhz, within spec(?) but too far off for reliable interPIC communications.
PostPosted: Sun May 08, 2011 4:14 pm     Reply with quote
Are these two PICs on separate boards ? Or are they on the same board ?
Is this a real hardware project, or is it a Proteus project ?
Post a list of connections between the two PICs for the SPI.
What is your compiler version ?
lglenat
PostPosted: Mon May 09, 2011 11:02 am     Reply with quote
Ok I will try with a crystal as soon as possible...
@PCM programmer :
- The two PICs are not on a PCB but on a prototyping board (white, with components linked with wires)
- The PICs are connected as below :
MASTER SLAVE
SDI SDO
SDO SDI
SCK SCK
RA3 SS (RA5)
- My compiler version is 4.093
I hope it will help, thank you both for your quick answers.
bkamen
PostPosted: Mon May 09, 2011 11:44 am     Reply with quote
temtronic wrote:
Two issues..
That shouldn't matter here since SPI is clocked.
-Ben
PostPosted: Mon May 09, 2011 11:54 am     Reply with quote
Are the two PICs on one (solderless) board, or are they on two boards ?
In other words, do you have a common ground connection between the two PICs ?
What is the power supply voltage for the PICs ? Is this a good, clean,
stable power supply voltage ?
SherpaDoug
PostPosted: Mon May 09, 2011 2:19 pm     Reply with quote
Try running the SPI at 1/10 speed and see if that makes a difference. Can you tell if the bad bits are always 1 or if they are always 0? The best thing is to put a dual trace oscilloscope on the lines.
lglenat
PostPosted: Mon May 09, 2011 3:34 pm     Reply with quote
@ PCM programmer
The PICs are on the same board, with same ground, same power supply.
The power supply voltage is 5V from a 1.5A DC regulated power supply, that is good power supply I think. I tried with a voltage regulator and with filtering capacitors (100u and 100n between gnd and vcc) but it didn't change anything.
@SherpaDoug : bad bits seem to be always 0, error is always 0 instead of 1.
I will try with an oscilloscope.
SherpaDoug
PostPosted: Mon May 09, 2011 6:48 pm     Reply with quote
From that info I would guess your SPI pull-up resistors are too high, or you have too much capacitance on your lines. If the 1/10 speed cures the problem then it is resistance/capacitance. If 1/10 speed does nothing then you have a pure voltage problem, like differing PIC voltage levels or leakage currents. Your scope should help find the problem.
lglenat
PostPosted: Tue May 10, 2011 12:28 pm     Reply with quote
I didn't kwow that spi required pull-up resistors. On what lines do you suggest I have to put pull-up resistors ?
PostPosted: Tue May 10, 2011 1:09 pm     Reply with quote
No, SPI doesn't need pull-up resistors as a requirement.
I haven't looked closely at your test program, and I haven't bread-
boarded it for a hardware test. But I suggest that you try two
different PICs from a different PIC family. The PICs that you are
using do have some erratas on the SPI. They might seem not to
apply in your case, but I think it's a good test to try it with different PICs.
lglenat
PostPosted: Wed May 11, 2011 12:46 pm     Reply with quote
- I just tried with two PIC18F2520 and I got the same problem.
- I change the board to eliminate this parameter.
- I tried to use a 20MHz crystal, pull-up resistors, changed nothing.
- When I debug the slave sometimes it's working (all the bytes received by the slave are those sent by the master), but i don't know why...
- Maybe there is a soft issue, or as Sherpadoug said a voltage issue.
PS : I haven't tried yet with a scope.
PostPosted: Wed May 11, 2011 12:57 pm     Reply with quote
Or it could be a test program issue. I didn't really look too closely at your
test program. I don't have time to put together a hardware test setup
today. Maybe I could do that tomorrow and test the problem.
lglenat
PostPosted: Wed May 11, 2011 2:16 pm     Reply with quote
It would be great !
Thank you anyway.
PostPosted: Thu May 12, 2011 6:14 pm     Reply with quote
I made a test that worked for the 16F877, but I haven't been able to make
it work for 18F PICs yet. There's something different with the compiler
or the MSSP modules in those PICs. I don't what it is yet. I'll investigate
it more tomorrow.
Goto page 1, 2  Next
Page 1 of 2
