calvin
| Int32 comparison problem |
Posted: Fri May 06, 2011 12:43 am |
Hi!
I have a the following code:
int32 AA,BB;
AA=-4;
if(AA > 0){
// do some thing 1
BB=0:
if(AA > BB){
// do some thing 2
Allways the code executes "do some thing 1" and "do some thing 2".
Why??
Thanks for your help |
calvin
| Another case: |
Posted: Fri May 06, 2011 1:01 am |
For more illustration:
if(-2 < -4){
EVENTO(196);
if(-2 > -4){
EVENTO(197);
CCS generates the following .lst
.................... if(-2 < -4){
.................... EVENTO(196);
.................... if(-2 > -4){
.................... EVENTO(197);
2156: MOVLW C5
2158: MOVWF x9C
215A: MOVLB 0
215C: CALL 0CE6
why??? |
Posted: Fri May 06, 2011 1:47 am |
With 8 Bit CCS compilers, int defaults to unsigned (unless overridden by a #TYPE statement).
So all negative constants are interpreted as positive values, the result is correct. |
calvin
Posted: Fri May 06, 2011 7:02 am |
| Thanks FvM I will read about that.But, is fine too that the compile doesnt generate code for some statements? that is not for signed or unsigned data types. |
SherpaDoug
Posted: Fri May 06, 2011 8:27 am |
If the compiler can tell at compile time that certain code can never be reached, it will not generate machine code for those statements. They are optimized out of existence. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Fri May 06, 2011 8:36 am |
| Quote: | | But, is fine too that the compile doesnt generate code for some statements? |
Sure. Conditional code after a constant compare that evaluates to false will be removed. |
calvin
Posted: Fri May 06, 2011 11:54 am |
| Thanks to all for your help. |
