ADC and serial transmission help
jayashree
PostPosted: Thu May 05, 2011 8:16 pm     Reply with quote
I am working on a project where i need to measure current and voltage values continuously and send it to zigbee.At receiver's end i am using one more zigbee and pic.In receiver's end i need to get the values continuously and display it on lcd.Pins b1,b2,b3 and b4 are connected to switches.When b1 is pressed voltage should be displayed,b2 current and b3 power.I am not able to do this continuously.I have to reset pic after executing once.How to do this continuously without resetting each time ?
In the transmitter side i need 10 bit adc to measure current.How to do that and transmit the 10 bit value through rs232?Can this be done in ccs?
I am using pic16f877a and ccs compiler.I am sending the transmitter and receiver side code
Transmitter side code
#include <16f877a.h>
#fuses HS,NOWDT
#use RS232(baud=9600,xmit=pin_c6,rcv=pin_c7)
#byte porta=0x05
#byte portc=0x07
#byte portb=0x06
unsigned int value;
unsigned int fvalue;
setup_port_a(ALL_ANALOG);
set_tris_a(0x03);
set_tris_c(0x80);
set_adc_channel(0);
delay_ms(10);
fvalue=read_adc();
putc(fvalue);
set_adc_channel(1);
delay_ms(10);
value=read_adc();
putc(value);
Receiver side code
#include<16f877a.h>
#fuses HS,NOWDT,NOLVP
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7)
#byte porta=05
#byte portb=06
#byte portc=07
#byte portd=0x08
#byte porte=0x09
#bit rs=porte.0
#bit rw=porte.1
#bit en=porte.2
#byte lcd=portd
void lcd_init();
void lcd_putc(char data);
void lcd_display(char var);
unsigned int value;
float v1,i1,power;
set_tris_a(0xff);
set_tris_b(0xff);
set_tris_c(0x80);
set_tris_d(0x00);
set_tris_e(0x00);
port_b_pullups(true);
lcd_display(0x80);
printf(lcd_putc,"%s","SKIT college");
if(!input(pin_b1) )
fvalue=getc();
v1=(5*((float)fvalue)/255);
lcd_display(0x80);
printf(lcd_putc,"%s","voltage ");
lcd_display(0xc0);
printf(lcd_putc,"%f",v1);
if(!input(pin_b2) )
value=getc();
i1=(5*((float)value)/255);
lcd_display(0x80);
printf(lcd_putc,"%s","current ");
lcd_display(0xc0);
printf(lcd_putc,"%f",i1);
if(!input(pin_b3) )
power=v1*i1*0.8;
lcd_display(0x80);
printf(lcd_putc,"%s","power ");
lcd_display(0xc0);
printf(lcd_putc,"%f",power);
void lcd_init()
int i=0;
char cmd[4]={0x38,0x0e,0x01,0x06};
for (i=0;i<4;i++)
lcd=cmd[i];
rs=0;
rw=0;
en=1;
delay_ms(25);
en=0;
lcd=data;
rs=1;
rw=0;
en=1;
delay_ms(25);
en=0;
lcd=var;
rs=0;
rw=0;
en=1;
delay_ms(25);
en=0;
jayashree
ezflyr
PostPosted: Thu May 05, 2011 9:16 pm     Reply with quote
To your specific question, you are probably overflowing the serial input buffer and causing your code to hang. Add the 'Errors' directive to the #use rs232 statement.
A couple of other things: You need to add the NOLVP fuse to the transmit code. You don't appear to be using any switch debouncing? Make your life easier by using 'Standard I/O' and get rid of all the TRIS statements. Make your life easier and use the Flex_LCD routines. Finally, clean up your code by getting rid of all the Port and Bit defines. At this point in your 'C' programming career, just use something like #define Switch1 Pin_B2 - your code will be much easier to read.
One last thing, use the CODE button for posting code in the forums.
John
PostPosted: Thu May 05, 2011 9:41 pm     Reply with quote
Along with all the previously said help..
It looks like your transmitter only sends 2 readings then goes to sleep. If you want continuous data, you'll have to have some form of loop..
Also you should have a way to tell WHICH reading is being sent(volts or amps).
SherpaDoug
PostPosted: Fri May 06, 2011 6:38 am     Reply with quote
10 bit A/D readings will be stored in a PIC as a 2 byte quantity. To send by RS232 you just send the 2 bytes. Look at the functions make8() and make16() to see how to pack and unpack bytes.
jayashree
PostPosted: Sat May 07, 2011 10:06 pm     Reply with quote
Thanks all for the help. I am still left with one problem. I am using ACS714 hall sensor to measure current values. The output of hall sensor is ac. So its rectified and given to channel 1. I am getting erratic values and I am not able to read 10 bit adc even after including #device adc=10.
//Transmitter
#include<16f877a.h>
#device ADC=10
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7,errors)
#byte porta=05
#byte portb=06
#byte portc=07
unsigned int value;
set_tris_a(0xff);
set_tris_b(0x00);
set_tris_c(0x80);
    putc('V');
    setup_adc_ports(ALL_ANALOG);
    setup_adc(ADC_CLOCK_INTERNAl);
    set_adc_channel(0);
    fvalue=read_adc();
    putc(fvalue);
    delay_ms(5);
    putc('C');
    set_adc_channel(1);
    value=read_adc();
    putc(value);
    delay_ms(5);
jayashree
PostPosted: Sun May 08, 2011 5:23 am     Reply with quote
Re-read SherpaDoug's reply !!!
SherpaDoug
PostPosted: Sun May 08, 2011 6:08 am     Reply with quote
These declarations:
unsigned int value;
declare 8 bit integers. There is no way for them to hold 10 bit values. You need to declare longer variables. And of course putc() is also only meant for 8 bits.
