ebalvis
| problem output RB6 RB7 PIN |
Posted: Wed Apr 27, 2011 1:49 am |
hi all, I can not activate the pins RB6 and RB7 as output.
The following example activates RB1. RB7 is always 0 volts.
The programming of the PIC with MPLAB ICD3 performed using MPLAB IDE.
Any ideas?
#include <16F818.h>
#FUSES NOWDT , NOPUT, INTRC_IO , MCLR , NOBROWNOUT , NOLVP , NOCPD , NOWRT, NODEBUG,NOPROTECT
#use delay(clock=8000000)
setup_oscillator(OSC_8MHZ);
while(true){
if (input(PIN_A4)) {
output_high(PIN_B1);
output_high(PIN_B7);
else{
output_low(PIN_B1);
output_low(PIN_B7);
FvM
Posted: Wed Apr 27, 2011 4:55 am |
| It works correctly with recent CCS C version. If you have an old version, check the actual fuse settings in MPLAB. |
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Wed Apr 27, 2011 5:30 am |
| ALSO be sure to set the MPLAB Project ,'build configuration' to 'release' from 'debug' , recompile (F10), then burn the PIC with that code. |
ebalvis
| Problem solved. |
Posted: Wed Apr 27, 2011 4:23 pm |
Project-> Build configuration-> release. Rebuild.
Thank you very much. |
