How can I make exact delay_us or pulse ?
soondin
PostPosted: Thu Apr 21, 2011 5:01 am     Reply with quote
Hello All,
Following is part of my code.
#int_ccp2
void isr()
rise = CCP_1;
fall = CCP_2;
p_wid = fall - rise;
setup_ccp1(CCP_CAPTURE_RE);
setup_ccp2(CCP_CAPTURE_FE);
setup_timer_1(T1_INTERNAL);
enable_interrupts(INT_CCP2);
us = p_wid/5;
output_low(PIN_A0);
delay_us (us);
output_high(PIN_A0);
delay_us (us);
Use that one, I try make square wave with CCP Capture interrupt.
But I can't make exact duration of wave.
when I check with Scope, some time be slight long what I want.
How can I make most same output from input pulse?
Please help me.
My PIC is 18F2550 with 20MHz.
PostPosted: Thu Apr 21, 2011 5:25 am     Reply with quote
Using your code....
You'll have to 'compensate' for the time to be in the ISR as well as your output.. functions.
Dump the listing, grab the datasheet and compute the time it takes to execute the instructions your program has.Then subtract the necessary instructions to make the output pulse the same width as the input pulse.
IE. if your input is 5 us 'wide' and the output is 7us 'wide', remove 2us of code.
You don't show how you declare your variables,but all should be int16 for better 'timing'
soondin
PostPosted: Thu Apr 21, 2011 6:19 am     Reply with quote
Thank you for reply.
unsigned long rise,fall,p_wid,us;
This is set of my Vals.
temtronic wrote:
Using your code....
PostPosted: Thu Apr 21, 2011 9:52 am     Reply with quote
There is no way to make an 'exact' delay in software, if the processor is doing other things in interrupts.
Realistically this is the whole 'point' of the PWM....
You could, depending on the pulse rate involved, use just one CCP, to record both edges, by programming it to (say) the rising edge. Then when you get the interrupt for this, record the value, and change it to record the falling edge. On the second interrupt, you then have both edges recorded. This would then leave the second CCP, available for use as a PWM.
For longer delays, you could do your delay using a loop, and a global counter, and if the interrupt gets called, decrement the counter by the amount corresponding to the interrupt overhead. You will still get a slight variation if the edge is needed at the moment the interrupt is called, but a lot 'better'. Alternatively, using a hardware timer, and calculating the 'count' corresponding to the required edge, would allow the error to reduce to at most the overhead from one interrupt, instead of being 'cumulative' (error gets worse with a simple delay, if the interrupt occurs multiple times in the delay....).
