Doralice
Joined: 03 Feb 2011 Posts: 5 Location: Florence, Italy
| Variables bit access |
Posted: Wed Apr 20, 2011 7:14 am |
Hi all!
How can I access directly a single bit of a variable, for example an int8 variable?
I need it because I work with PIC12F683 and I have to use ADC and PWM with 10 bits. I'll store the result of the conversion and the duty cycle in two 16 bits variables.
Otherway I'll do this:
unsigned int16 pippo,pluto;
pippo=ADRESL;
pippo=pippo>>6;
pluto=ADRESH;
pluto=pluto<<2;
10_bit_result=pippo+pluto;
and something similar with duty cycle...
Doralice _________________ Bugs will appear in one part of a working program when another 'unrelated' part is modified.
Doralice |
SherpaDoug
Posted: Wed Apr 20, 2011 8:06 am |
CCS has bit-set(), bit_clear(), and bit_test(). A more transportable method is to AND or OR with a bit mask. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Apr 20, 2011 8:37 am |
Er. Why bother?.
If you have selected #device ADC=10, the compiler does the ADC conversion for you. Just:
int16 adcval;
adcval=read_adc();
This puts the 10bit result, right justified into a 16 bit variable for you.
Similarly, with the PWM:
int16 duty;
duty =500
set_pwm1_duty(duty);
Writes the 10 bit value from the bottom 10 bits of the 16bit value 'duty', into the two registers for the PWM.
The compiler does jobs like this for you, faster than you could code them
You are 'making work'. The chip can be told to return the number right justified or left justified. What you show is the code needed to convert a left justified number (#device ADC=16) to a right justified one. But why not just set the chip to return the number right justified?....
Doralice
Posted: Wed Apr 20, 2011 8:54 am |
Thank you both!
You've given me some useful advice.
I didn't know such kinds of functions.
Doralice |
Joined: 01 Jul 2010 Posts: 9656 Location: Greensville,Ontario
Posted: Wed Apr 20, 2011 10:44 am |
| Pressing F11 while in a project will open up the onscreen help file. Jammed FULL of useful stuff to know! I leave it open all the time, to quickly reference when I ned to know something about a function or error messages. |
