PIC18F85K22 UART2
embedder
PIC18F85K22 UART2
PostPosted: Fri Apr 08, 2011 9:27 am     Reply with quote
I am having a problem getting UART2 to work on PIC18F85K22. I can see valid characters getting to the RX2 pin (7 / RG2) on the 'scope, but no response or break from from kbhit() or fgetc(). I tried changing the port to a SW UART, but no luck. UART2 transmits OK, but no RX. UART1 works fine. Is there a bug or have I missed something "obvious"? Thanks for reading...
#include <18F85K22.h>
#define DEBUG_MODE  // comment-out for stand-alone operation
#ifdef DEBUG_MODE
   #device ICD=TRUE
#endif
#ifdef DEBUG_MODE
   #FUSES MCLR
#else
   #FUSES NOMCLR
#endif
#device adc=12
#FUSES NOWDT                    // No Watch Dog Timer
#FUSES WDT128                   // Watch Dog Timer uses 1:128 Postscale
#FUSES SOSC_DIG                 // Enables C0 & C1 as digital I/O
#FUSES NOXINST                  // Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PUT                      // Power Up Timer
#FUSES NOBROWNOUT               // No brownout reset
#FUSES WDT_NOSLEEP
#FUSES NOEXTADDRSFT
#FUSES RTCOSC_INT
#FUSES HSM
#FUSES INTRC_HP
#FUSES PLLEN
#use delay(clock=16000000)
#use rs232(UART1, baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=COM_A,errors)
#use rs232(UART2, baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,stream=COM_B,errors)
// RS232
#define MDX_SHDN     PIN_G0
#define MD1_TXEN     PIN_C0
#define MD1_REN      PIN_C1
#define MD2_TXEN     PIN_G3
#define MD2_REN      PIN_G4
char cmd;
void init()
   // RS232
   output_high(MDX_SHDN);   // MAX3323 ON
   output_high(MD1_REN);    // Rx enable
   output_high(MD1_TXEN);   // Tx enable
   output_high(MD2_REN);    // Rx enable
   output_high(MD2_TXEN);   // Tx enable
   delay_ms(20);
   disable_interrupts(GLOBAL);
   setup_adc_ports(ALL_ANALOG|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
   setup_wdt(WDT_OFF);
   setup_oscillator(OSC_16MHZ);
   init();
   fprintf(COM_A, "NYMPH COM_A\r\n");
   fprintf(COM_B, "NYMPH COM_B\r\n");
   while (TRUE) {
      if(kbhit(COM_A)){
         cmd=fgetc(COM_A);
         fputc(cmd,COM_A);
      if(kbhit(COM_B)){
         cmd=fgetc(COM_B);
         fputc(cmd,COM_B);
   reset_cpu();
embedder
PostPosted: Fri Apr 08, 2011 9:35 am     Reply with quote
Compiler V4.119
PostPosted: Fri Apr 08, 2011 5:01 pm     Reply with quote
setup_wdt(WDT_OFF);
The UART2 pins are set as analog pins by the line in bold.
They should be configured as digital pins.
You are setting ALL 24 pins that can be analog, as analog pins.
You should change it to select the specific analog pins that you need.
There are 24 analog-configurable pins on this PIC.
Also, in your program you are enabling/disabling Global interrupts.
There is no need for this. You have no interrupt routines.
embedder
PostPosted: Fri Apr 08, 2011 5:17 pm     Reply with quote
Excellent catch. Thank you!
(I plan to have some interrupt routines in the near future).
PostPosted: Fri Apr 08, 2011 6:31 pm     Reply with quote
Ever since the design guys figured out you could 'multipurpose' a pin, it's been a battle to get the 'correct' configuration.
Things were easier back in the days of 8008s, teletypes and papertape !
embedder
PostPosted: Mon Apr 11, 2011 8:18 am     Reply with quote
That was it PCM programmer. Thanks for your help. Caught-out by the doubled edged sword of multi-purpose pins.
