pic16f88 LED flasher
indep
PostPosted: Fri Apr 01, 2011 7:25 am     Reply with quote
hello dear friends
is there anyone can give me sch and assembly code for a simple LED flasher using pic16f88 Smile many thanks
PostPosted: Fri Apr 01, 2011 1:05 pm     Reply with quote
Here is a 16F88 program to flash an LED:
http://www.ccsinfo.com/forum/viewtopic.php?t=34839&start=3
Here is a schematic. Note that the cathode of the LED must connect
to ground:
pin      330 ohms      LED
A1    ---/\/\/\/------->|----
                          -----  Ground
indep
hello PCM
PostPosted: Tue Apr 05, 2011 7:51 am     Reply with quote
i have my basic assembly code for LED FLASHER
but when i am trying to compile it using MPLAB,
i am getting an error in the __CONFIG part is says
Error[126] F:\RALPH\FLASHER.ASM 33 : Argument out of range (not a valid config register address)
here my code:
; HEAD88.ASM  for 16F88. This sets PORTA as digital INPUT. PORTB is an OUTPUT.
;Internal oscillator of 31.25kHz chosen
; The OPTION register is set to /256 to give timing pulses of 32.768ms with 31.25kHz crystal.
; 1second and 0.5 second delays are included in the subroutine section.
; EQUATES SECTION
TMR0       EQU        1          ;means TMR0 is file 1.
STATUS     EQU        3         ;means STATUS is file 3.
PORTA      EQU        5          ;means PORTA  is file 5.
PORTB        EQU        6          ;means PORTB is file 6.
ZEROBIT    EQU        2          ;means ZEROBIT is bit 2.
ADCON0     EQU        1FH          ;A/D Configuration reg.0
ANSEL        EQU        9BH
ADRES      EQU        1EH        ;A/D Result register.
CARRY      EQU           0             ;CARRY IS BIT 0.
TRISA      EQU   85H
TRISB      EQU   86H
OPTION_R    EQU   81H
OSCCON      EQU   8FH               ;Oscillator control register.
COUNT      EQU        20H        ;means COUNT is file 20H, a register to count events.
LIST       P=16F88           ;we are using the 16F818.
ORG        0                  ;the start address in memory is 0
GOTO    START              ;goto start!
; Configuration Bits
__config H'3F10'      ;sets INTRC-A6 is port I/O, WDT off, PUT on, MCLR tied to VDD A5 is I/O
         ;BOD off, LVP disabled, EE protect disabled, Flash Program Write disabled,
      ;Background Debugger Mode disabled, CCP function on B2, Code Protection  ;disabled.
;SUBROUTINE SECTION.
; 0.1 second delay, actually 0.099968s
DELAYP1    CLRF    TMR0                       ;START TMR0.
LOOPB      MOVF      TMR0,W                     ;READ TMR0 INTO W.
      SUBLW      .3                         ;TIME - 3
      BTFSS   STATUS,ZEROBIT             ; Check TIME-W = 0
      GOTO      LOOPB                      ;Time is not = 3.
      NOP               ;add extra delay
      NOP
      RETLW      0                          ;Time is 3, return.
; 0.5 second delay.
DELAYP5     MOVLW   .5
      MOVWF   COUNT
LOOPC      CALL   DELAYP1
      DECFSZ   COUNT
      GOTO   LOOPC
      RETLW      0
; 1 second delay.
DELAY1     MOVLW   .10
      MOVWF   COUNT
LOOPA      CALL   DELAYP1
      DECFSZ   COUNT
      GOTO   LOOPA
      RETLW      0
;Configuration Section
START      BSF        STATUS,5           ;Turns to Bank1.
      MOVLW      B'11111111'        ;PORTA is I/P
      MOVWF      TRISA
      MOVLW      0              ;PORTA IS DIGITAL
      MOVWF      ANSEL
      MOVLW      B'00000000'
      MOVWF      TRISB              ;PORTB is OUTPUT
      MOVLW      B'00000000'
      MOVWF      OSCCON              ;oscillator 31.25kHz
      MOVLW      B'00000111'           ;Prescaler is /256
      MOVWF      OPTION_R           ;TIMER is 1/32 secs.
      BCF        STATUS,5           ;Return to Bank0.
      CLRF       PORTA              ;Clears PortA.
      CLRF       PORTB              ;Clears PortB.
;Program starts now.
BEGIN   BSF   PORTB,0   ;Turn ON B0.
   CALL   DELAYP5   ;Wait 0.5 seconds
   BCF   PORTB,0   ;Turn OFF B0.
   GOTO    BEGIN   ;Repeat
END                   ;YOU MUST END!!
dyeatman
PostPosted: Tue Apr 05, 2011 8:01 am     Reply with quote
You are in the wrong place... This is not an assembly code forum. It is the
CCS C code forum.
The Microchip forums are located here:
http://www.microchip.com/forums/Default.aspx?
Google and Forum Search are some of your best tools
indep
PostPosted: Tue Apr 05, 2011 8:09 am     Reply with quote
ohh okay.. still if you put that __CONFIG in C its still having error..
Also i wanted to know how can you put your assembly in C code? Because in my other project in assembly code as well i have a digital value and i need to convert it to voltage again, it is awkward to do dividing in assembly, can you put .asm file to C then do the dividing through C?? thanks
PostPosted: Tue Apr 05, 2011 8:34 am     Reply with quote
Yes, you can easily 'insert' assembly into CCS C by using the preprocessor directives #asm, #endasm. Either download the manual or press F11 in an open project to read about it.
indep
PostPosted: Tue Apr 05, 2011 8:38 am     Reply with quote
where could i find the manual?! thanks.. Smile
dyeatman
PostPosted: Tue Apr 05, 2011 8:54 am     Reply with quote
The CCS C manual can be found here:
http://www.ccsinfo.com/downloads.php
