arunkish
| UART RX Problem |
Posted: Fri Apr 01, 2011 8:40 pm |
Dear All,
I am having a problem with UART. I am using 18F4620 clocked at 4 Mhz. uc hangs when it receives serial data sent from another uc. I also used getc, but still I don't have any progress. I have completely checked the hardware on both sides. I can read the serial data in PC sent from the other TX controller. Likewise my receiving controller reads the data when sent from the PC. But if I connect both controllers, it hangs and sometimes it receives junk characters. Please advise.
#fuses XT,PROTECT,PUT,NOBROWNOUT,NOLVP,NOWDT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
#INT_RDA
void serial_reciv_int(void)
clear_line(2);
lcd_gotoxy(1,2);
for(i=0;i<=8;i++)
lcd_putc(rxmessage[i]);
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Fri Apr 01, 2011 11:57 pm |
That's your whole program?
How can that compile with no main()?? _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
arunkish
Posted: Sat Apr 02, 2011 2:22 am |
| That's not my whole program. I have just given you the section of code. |
Posted: Sat Apr 02, 2011 2:35 am |
Key thing that is wrong, is what int_rda does....
You need to understand what INT_RDA implies. It triggers when _one_ character is ready to be read from the serial. The handler need to do just one thing. Read this character. This is _all_ it should do, and what it _must_ do.
Your INT_RDA, does not read the character. Unless it does, the code will hang for ever, looping back to the interrupt as soon as you exit the interrupt.
Instead your INT_RDA code, writing 8 characters to the LCD (and clearing a screen line, which takes even longer).
Look at the EX_SISR. c example, which shows what an INT_RDA, _should_ do. save the characters, so that the external code can use them when _it_ is ready to.
