muzakyo
| LCD 16x2 with pic16f877a |
Posted: Thu Mar 31, 2011 8:37 pm |
Hello i am truly newbie in the ccs programming.
Right now i am doing my project for solar tracker.
So i just create program and i don't know what is the problem with it.
So please help me correct this program.
Maybe some of the mistake really simple but i am truly new in this field...
This my program
sensor cds at port a
lcd at port d
motor at port c
#include <16f877a.h>
#device adc=8
#use delay(clock=200000000)
#fuses hs, noprotect, nowdt, nolvp
#define <lcd.c>
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
int r1, r2, r3;
set_tris_a(0b11111111);
set_tris_b(0b11111111);
set_tris_c(0b00000000);
set_tris_d(0b00000000);
setup_port_a(ALL_ANALOG);
setup_adc( ADC_CLOCK_INTERNAL );
do
set_adc_channel(0);
delay_ms(10);
r1=read_adc();
set_adc_channel(1);
delay_ms(10);
r2=read_adc();
lcd_gotoxy(5,1);
lcd_putc("sensor 1 = ");
lcd_putc(%r1\n);
lcd_putc("\f");
lcd_gotoxy(5,2);
lcd_putc("sensor 2 = ");
lcd_putc(%r2\n);
if(r1=r2)
void motor_stp1()
else if(r1 > r2)
void motor_fwd()
else if(r1 < r2)
void motor_bwd()
else if((r1 >= 205)||(r2 >= 205))
void motor_stp1()
else if((input_high(PIN_B1))&&(input_low(PIN_B2)))
void hold()
else if((input_high(PIN_B2))&&(input_low(PIN_B1)))
void face_east()
output_low(PIN_C0);
output_low(PIN_C1);
void motor_fwd()
r3 = r1 - r2
if(r3 > 10)
output_high(PIN_C0);
output_low(PIN_C1);
delay_us(280);
void motor_bwd()
r3 = r2 - r1
if(r3 > 10)
output_low(PIN_C0);
output_high(PIN_C1);
delay_us(280);
void motor_stp1()
output_low(PIN_C0);
output_low(PIN_C0);
delay_us(280);
void face_east()
output_low(PIN_C0);
output_low(PIN_C0);
SLEEP(14400);
output_low(PIN_C0);
output_hight(PIN_C1);
delay_us(280);
void hold()
output_low(PIN_C0);
output_low(PIN_C0);
SLEEP(3600);
Posted: Thu Mar 31, 2011 11:31 pm |
I count at least 10 errors in syntax. You need to learn C.
We can't learn it for you. You need to compile the code and
fix each one of the errors. Look in the CCS manual and
learn how to use the CCS functions. Learn the correct names
for the functions.
We don't want to have you spend one hour learning C, and
then have us fix all your coding mistakes. That's not the purpose
of this forum. It's not a C learning forum.
If you had only 1 or 2 errors, and you were trying hard to learn
then it would be OK. But you have 10+ errors. You need to
study and fix the errors. |
hussain_kiet
Posted: Fri Apr 01, 2011 12:53 am |
The problem is very simple "Syntax Error..."
Have you compiled the code..?
it is probably the easiest of errors to fix, the compiler guides you with each error.... _________________ !!!!...HUSSAIN AFTAB...!!!! |
Wayne_
Posted: Fri Apr 01, 2011 1:37 am |
This line will compile but is most likely wrong :-
What you are doing is an assignment, set r1 to have the same value as r2 and if it is not 0 (not FALSE but TRUE >0) then ...
To do a check for equality in a C if statement it is == so
muzakyo
Posted: Fri Apr 01, 2011 10:01 am |
tq...
i don't know what the problem here, there is error with this program
else if(r1 > r2)
void motor_fwd()
i try to test my lcd but its didn't work properly, i already run it and tested on lcd.
#device adc=8
#include <lcd.c>
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
int r1, r2, r3;
do
set_adc_channel(0);
delay_ms(10);
r1=read_adc();
set_adc_channel(1);
delay_ms(10);
r2=read_adc();
lcd_putc("\f");
lcd_gotoxy(5,1);
lcd_putc(r1);
lcd_putc("\n");
lcd_gotoxy(5,2);
lcd_putc(r2);
Posted: Fri Apr 01, 2011 10:40 am |
Your PIC will NOT run with 200,000,000 Hz xtal !
It helps if you put commas in big numbers to quickly see errors like this .. |
muzakyo
Posted: Fri Apr 01, 2011 12:19 pm |
i use lcd from cytron.com 16x2. did i need put this command in my programm...?
#define rs RB4
#define e RB5
#define lcd_data PORTD
#define SW1 RB0
#define SW2 RB1
#define LED1 RB6
#define LED2 RB7 |
muzakyo
Posted: Sat Apr 02, 2011 6:17 am |
someone please comment my program.... ? i dont know where the mistake i do ......
#fuses hs,noprotect,nowdt, nolvp
#define use_portd_lcd TRUE
#include <lcd.c>
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
void motor_fwd();
void motor_stp1();
void motor_bwd();
void face_east();
void hold();
int r1, r2, r3;
do
set_adc_channel(0);
delay_ms(10);
r1 = read_adc();
set_adc_channel(1);
delay_ms(10);
r2 = read_adc();
lcd_putc("\f");
lcd_gotoxy(5,1);
lcd_putc(r1);
lcd_putc("\n");
lcd_gotoxy(5,2);
lcd_putc(r2);
if(r1 == r2)
void motor_stp1();
else if(r1 > r2)
void motor_fwd()
else if(r1 < r2)
void motor_bwd()
// motor programming
if(input(pin_b2)==0)
void hold()
void motor_stp1()
if(input(pin_b3)==0)
void face_east()
void motor_stp1()
output_low(PIN_C0);
output_low(PIN_C1);
void motor_fwd()
r3 = r1 - r2
if(r3 > 10)
output_low(PIN_C1);
delay_us(280);
void motor_bwd()
r3 = r2 - r1
if(r3 > 10)
output_low(PIN_C0);
delay_us(280);
void motor_stp1()
output_low(PIN_C0);
output_low(PIN_C0);
delay_us(280);
void face_east()
output_low(PIN_C0);
output_low(PIN_C0);
SLEEP(14400);
output_low(PIN_C0);
delay_us(280);
void hold()
output_low(PIN_C0);
output_low(PIN_C0);
SLEEP(3600);
Posted: Sat Apr 02, 2011 6:53 am |
I suggest the following
1) remove the set_tris_x... lines, let the compiler do that for you automatically. If you do it wrong, you run into problems !
2) breakdown the program into two sections.
a) get the LCD to function correctly do the classic 'Hello World' program.
b) then just read and display the two voltages in a loop, say every 500ms.
If you can't get the LCD driver working right, use the flexlcd driver ( that's what I use all the time).
3) now add your 'motor control logic 'code, but display the result on the LCD, this will SHOW you the result of your actions. If the action is supposed to STOP the motors, display STOP on the LCD.
4) once you have it right, then add the code to turn on/off the motor signals.
I save each version of my programs as programnameV1, ...V2,...V3,etc. that way I can always go back to a known good program and make changes, save as version +1, it is too difficult to rememeber what worked, what didn't after a few hours ! It is common for me to have 30-40 'versions' of the program. Once the project is completed, all but the last 3 are erased. |
muzakyo
Posted: Sat Apr 02, 2011 12:50 pm |
in this part always show "undefined identifier r1" when i compile the program... why?
else if(r1 > r2)
void motor_fwd()
Posted: Sat Apr 02, 2011 2:48 pm |
Because r1, r2, and r3, are declared as _local_ variables inside main, then you try to use them inside the motor routines.
muzakyo
Posted: Sun Apr 03, 2011 5:18 am |
After do the the change the program become like this. Please anyone give comment to this program....?
#include <lcd.c>
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
void motor_fwd();
void motor_stp1();
void motor_bwd();
void face_east();
void hold();
int r1, r2, r3;
// sensor programming
set_adc_channel(0);
delay_ms(10);
r1=read_adc();
set_adc_channel(1);
delay_ms(10);
r2=read_adc();
// LCD programming
lcd_putc("\f");
lcd_gotoxy(2,1);
lcd_putc(r1);
lcd_gotoxy(2,2);
lcd_putc(r2);
if(r1 == r2)
void motor_stp1();
else if(r1 > r2)
void motor_fwd();
else if(r1 < r2)
void motor_bwd();
// switch programming
void hold();
void motor_stp1();
void face_east();
void motor_stp1();
output_low(PIN_C0);
output_low(PIN_C1);
void motor_fwd()
r3 = r1 - r2;
if(r3 > 10)
output_low(PIN_C1);
delay_us(280);
do
lcd_putc("\f");
lcd_putc("motor action\n");
lcd_putc("FOWARD");
while(0);
void motor_bwd()
r3 = r2 - r1;
if(r3 > 10)
output_low(PIN_C0);
delay_us(280);
do
lcd_putc("\f");
lcd_putc("BACKWARD");
while(0);
void motor_stp1()
output_low(PIN_C0);
output_low(PIN_C0);
delay_us(280);
do
lcd_putc("\f");
lcd_putc("STOP");
while(0);
void face_east()
output_low(PIN_C0);
output_low(PIN_C0);
sleep();
output_low(PIN_C0);
delay_us(280);
void hold()
output_low(PIN_C0);
output_low(PIN_C0);
sleep();
Posted: Sun Apr 03, 2011 2:34 pm |
It'll sleep for ever.
What is going to wake it up?.
muzakyo
Posted: Tue Apr 05, 2011 9:02 am |
Why when I try the lcd there are nothing display on it? It is look like below picture nothing on it....
this is the program:-
#include <16F877a.h>
#include <math.h>
#include <stdlib.h>
#include <float.h>
#include <lcd.c>
// Main
SETUP_ADC_PORTS(NO_ANALOGS);
lcd_init(); // Always call this first.
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
Posted: Tue Apr 05, 2011 4:28 pm |
Are you using the Flex lcd driver or the CCS lcd driver ?
Flex driver is here:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
CCS driver is here:
| Quote: |
c:\program files\picc\drivers\lcd.c
1. Post a list of the connections between the LCD and the PIC.
2. If you're using the Flex driver, post a list of the #define statements
at the top of the file (edited by you, to match the connections on your
board, between the PIC and the LCD).
3. Measure the voltage on pin 3 of the LCD. What is it ? It should be
approximately 0.5 volts. |
