lcd problem
reptile404
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
lcd problem
PostPosted: Fri Apr 01, 2011 7:09 am     Reply with quote
hello guys , what's up ?
i have a problem when i want to use lcd
for example this is the simplest code ever :
pic16f876a
#include "lcd4447.h"
#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B3
#define LCD_TYPE 1
#include <lcd.c>
   lcd_putc("\fReady...\n");
   while (TRUE) {
      k=kbd_getc();
      if(k!=0)
        if(k=='*')
          lcd_putc('\f');
          lcd_putc(k);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1););
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
But when I compile it many errors will appear like this one:
an Expression must be a constant or simple variable
  BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
Maybe compiler did not know these functions :
lcd_init(),lcd_putc()....etc or #include <lcd.c>
So, what I have to do ?
REPTILE404
55AA55AA55
PostPosted: Fri Apr 01, 2011 8:21 am     Reply with quote
Are you compiling directly in CCS, or under MPLAB?.
If the latter, you _must_ only include your main program code file in the list of files to compile. If you add the 'lcd.c' file, MPLAB tries to compile this on it's own, and then lacks the processor definitions etc., and gives the errors you are describing.
reptile404
hello
PostPosted: Fri Apr 01, 2011 11:22 am     Reply with quote
thanks for respond.
I've compiled it using both ccs directly and under mplab
and had same problem.
REPTILE404
55AA55AA55
PostPosted: Fri Apr 01, 2011 11:32 am     Reply with quote
if that's your entire program, then it's missing the
#include ..processortype line
which should be the first line of code....
