lcd clear
matcobra
lcd clear
PostPosted: Fri Mar 25, 2011 10:06 am     Reply with quote
Hi, can anyone help me how to clear text on lcd then after the next text will show. Example, my coding
#include <16F877A.h>
#device adc=10
#use delay(clock=10000000)
#include <lcd.c>
#define x input (pin_b0) // ph output
#define y input (pin_b1) // voltage output
//#define z input (pin_b2) // glucose output
int16 adc_value;
float value1;
float value2;
float volt;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
value1=read_adc();
value2=(value1*5)/1023;
volt=value2*2 ;
   lcd_putc("\f----:FRUITi:----\n");
if(x==1)
     if((volt>5.00)&&(volt<=10.00))
     {printf(lcd_putc,"T:SWEET",);
      printf(lcd_putc,"G:MANY)",);delay_ms(100);}
     else if((volt>3.00)&&(volt<=5.00))
     {printf(lcd_putc,"T:SWEETSOUR",);delay_ms(3100);}
     else if((volt>0.00)&&(volt<=3.00))
     {printf(lcd_putc,"T:SOUR",);delay_ms(3100);}
if(y==1)
   {printf(lcd_putc,"VOLTAGE:%3.2f",volt);delay_ms(3100);}
Based on my coding example...I want to show text "SWEET" 1st then after that LCD screen need to clear then it will showing "MANY". The problem is I dunno how to clear text "SWEET" 1st before showing "MANY". Anyone can help me out for my problem ?
I'm sorry bcause my english vocabulary no so good.
PostPosted: Fri Mar 25, 2011 10:56 am     Reply with quote
'/f'
If you send this to the LCD, using either 'lcd_putc', or a printf to lcd_putc, it clears the screen.
It is the character for a terminal 'form feed'.
matcobra
PostPosted: Fri Mar 25, 2011 11:20 am     Reply with quote
oh ok...then how how i must suposed add that inside my coding....can u show how?
vinniewryan
PostPosted: Fri Mar 25, 2011 11:44 am     Reply with quote
#device adc=10
#include <lcd.c>
int16 adc_value;
float value1;
float value2;
float volt;
set_adc_channel(0);
value1=read_adc();
volt=value2*2 ;
if(x==1)
     {printf(lcd_putc,"T:SWEET \f",);
      printf(lcd_putc,"G:MANY \f)",);delay_ms(100);}
     {printf(lcd_putc,"T:SWEETSOUR \f",);delay_ms(3100);}
     {printf(lcd_putc,"T:SOUR \f",);delay_ms(3100);}
if(y==1)
      printf(lcd_putc,"VOLTAGE:%3.2f \f",volt);delay_ms(3100);}
lcd_putc('\f');
Your LCD should be clearing on your first putc() line. What LCD are you using?
Vinnie Ryan
matcobra
PostPosted: Fri Mar 25, 2011 12:17 pm     Reply with quote
i used 16x2 lcd,oh okay..i just tried test coding based on ur new post...it's worked...but it clear 1st row also..hmm i just want to clear second row only
matcobra
PostPosted: Fri Mar 25, 2011 12:18 pm     Reply with quote
vinniewryan
PostPosted: Fri Mar 25, 2011 12:53 pm     Reply with quote
just remove all of the "\f" that you dont want. If you only want it to clear the second row, then remove the \f from the first row.
Cheers
#device adc=10
#include <lcd.c>
int16 adc_value;
float value1;
float value2;
float volt;
set_adc_channel(0);
value1=read_adc();
volt=value2*2 ;
   lcd_putc("----:FRUITi:----\n");
if(x==1)
if(y==1)
Notice how each row has "\f" at the end. Remove this for each line you 'DON'T' want to clear.
Vinnie Ryan
