mdemuth
Joined: 16 Apr 2007 Posts: 71 Location: Stuttgart, Germany
| INT_RB is not working with 18f45k22(solved) |
Posted: Wed Mar 23, 2011 11:31 am |
Hello there,
I am trying to force an IRQ on pin change on port b.
// CCS Compiler Version: 4.119
#include <18f45k22.h> //
#device ADC=10 //
#fuses INTRC_IO,NOWDT,NOPROTECT,BROWNOUT,PUT,MCLR, BORV27
#use delay(clock=64000000)
#use fast_io(b)
// Schaltausgänge
#define LED_GN PIN_B1
#define LED_RT PIN_B0
// Encoder
#define X_SPUR_A PIN_B4
#define X_SPUR_B PIN_B5
#define Y_SPUR_A PIN_B6
#define Y_SPUR_B PIN_B7
// LCD
#define LCD_DATA_PORT getenv("SFR:PORTD")
#define LCD_ENABLE_PIN PIN_E0 ////
#define LCD_RS_PIN PIN_E1 ////
#define LCD_RW_PIN PIN_E2 ////
#define LCD_DATA4 PIN_D4 ////
#define LCD_DATA5 PIN_D5 ////
#define LCD_DATA6 PIN_D6 ////
#define LCD_DATA7 PIN_D7
#include "lcd.c"
int8 i=0;
int8 j=0; // Schleifenzähler
int8 x_new, y_new;
signed int16 x_wert=0;
signed int16 y_wert=0;
#include <Encoder Anzeige.h>
#zero_ram
setup_oscillator (OSC_64MHZ);
SETUP_ADC_PORTS(sAN0 | sAN1 | sAN2 | sAN3);
SETUP_ADC(ADC_CLOCK_INTERNAL);
SETUP_DAC(DAC_OFF);
setup_comparator(nc_nc_nc_nc);
SETUP_WDT(WDT_OFF); //WDT
RESTART_WDT(); // Initialisierung
set_tris_b (0xf0);
port_b_pullups(TRUE);
lcd_init();
i=input_b();
delay_us(10); //ensure line has time to settle
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
if (input(X_SPUR_A)) x_wert++; // HW works fine, I can read this input
if (!input(X_SPUR_B)) y_wert++; // HW works fine, I can read thsi input
lcd_gotoxy(1, 1);
printf(lcd_putc, "X=%05ld",x_wert);
lcd_gotoxy(1, 2);
printf(lcd_putc, "Y=%05ld",y_wert);
if (bit_test(i,0))
output_low(LED_RT);
output_high(LED_GN);
output_low(LED_GN);
output_high(LED_RT);
delay_ms(10);
} // Ende while 1
} // Ende main
#INT_RB
void IRQ_XY()
j=input_b(); // to clear the IRQ
i++; // i remains 0
lcd_gotoxy(12, 1);
printf(lcd_putc, "%03u",i);
No success so far, what is wrong?
Thanks in advance!
Michael
Posted: Wed Mar 23, 2011 12:33 pm |
Make a much more simple test program. Remove all the ADC code,
and the WDT code, and remove all the code in the while() loop.
Just test only the #int_rb problem. If you make a small program
and it still doesn't work, then I'll look at it.
Also, describe the input signal that is supposed to cause the #int_rb
interrupt. What are the voltage levels of this signal (high and low levels) ?
What is the Vdd voltage of the PIC ?
Here is a small test program for #int_rb on pin B7 only:
http://www.ccsinfo.com/forum/viewtopic.php?t=41951&start=1
Possible compiler bugs that could cause the problem, with fixes:
http://www.ccsinfo.com/forum/viewtopic.php?t=40980 |
mdemuth
Posted: Thu Mar 24, 2011 2:18 am |
Hi PCM programmer,
I made a very simple program:
//// CCS Compiler Version: 4.119
#device ADC=10 //
#use fast_io(b)
#byte IOCB = 0xF7D
#byte ANSEL = 0xF7E
#byte ANSELH = 0xF7F
int8 j=0;
void flash_led() // flashes LEDs
for (j=0; j<10;j++)
output_toggle(LED_RT);
#zero_ram
IOCB = 0xF0;
ANSEL = 0;
ANSELH = 0;
set_tris_b (0xf0);
j=input_b(); // read the inputs and clear the IRQ
// flash once to check this subroutine
flash_led();
// works fine => LED flashes
if (input(X_SPUR_A)) output_low(LED_RT);
else output_high(LED_RT);
// LED has same state as input => HW is OK
} // Ende while 1
} // Ende main
#INT_RB
void IRQ_XY()
flash_led(); // IRQ should force flashing, but does not!
VDD=5V Input is a simple switch.
#INT_RB is never called.
More assistance needed.....
Michael |
Posted: Thu Mar 24, 2011 3:11 pm |
I modified the program and now it works. The LED flashes when the
program starts. Then when you push a button on pin B4, the LED will
flash again. The main problem is that in vs. 4.119, the IOCB register
address is incorrect.
#include <18F45k22.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,BROWNOUT,PUT,MCLR, BORV27,NOPBADEN
void setup_IOCB(int8 mask)
#byte IOCB = 0xF62 // Register address for 18F45K22
IOCB = mask;
void flash_led(void)
int8 j=0;
for(j=0; j<10;j++)
#int_rb
void IRQ_XY(void)
int temp;
flash_led();
temp = input(PIN_B4); // To clear mismatch condition
int temp;
output_low(LED_RT); // LED is initially Off
port_b_pullups(0x10); // Enable pull-up on pin B4 only
temp = input(PIN_B4); // Read Pin B4 to clear mismatch condition
enable_interrupts(INT_RB4); // Enable int-on-change for pin B4 only
setup_IOCB(0x10); // *** Fixes bug with ASM code for line above
flash_led();
mdemuth
Posted: Mon Mar 28, 2011 3:26 am |
This looks much better => solved!
Thanks!  |
