luckyboy
| Transfer data in SPI interface |
Posted: Mon Mar 14, 2011 11:51 pm |
| Hi, everybody. I use SPI interface to transfer data between two pic 16f877a. I transfered integer very successful but when I transfer float data or string, I did not transfer. Can you help me to transfer float or string in SPI interface. I am using CCS. |
hayee
Posted: Tue Mar 15, 2011 12:05 am |
| You cannot directly send the floating or string through spi, you have to break the floating number into 4bytes and then send it using spi. |
luckyboy
Posted: Tue Mar 15, 2011 12:33 am |
| Thanks you, Can you write code for 16f877a in SPI interface. I try test code for 18f252 but I don't success. |
luckyboy
Posted: Tue Mar 15, 2011 12:52 am |
| Great, I transfer float data successful. |
semmoor
| Hi |
Posted: Mon Jul 02, 2012 5:05 pm |
| luckyboy wrote: | | Great, I transfer float data successful. |
can you please share the code? if you don't mind. |
Gabriel
Posted: Mon Jul 02, 2012 10:30 pm |
| Quote: | | Can you write code for 16f877a in SPI interface |
I believe the general answer from the guys here will be a redundant: "NO"
... imagine people cursing while you read such answer the next time you ask somthing like that.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
bkamen
Posted: Mon Jul 02, 2012 10:44 pm |
| Gabriel wrote: | | Quote: | | Can you write code for 16f877a in SPI interface |
redundant and emphatic. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
