PIC card with Ethernet
SherpaDoug
PostPosted: Wed Mar 09, 2011 11:10 am     Reply with quote
Does anyone know where I might get a PCB with Ethernet and a moderate sized PIC? I can start with the CCS development boards and then layout my own without all the knobs and LCDs, but I would rather just buy something.
I need to get a PIC to extract some data from a broadcast Ethernet stream, and generate a sync pulse when it finds what it wants.
asmallri
PostPosted: Wed Mar 09, 2011 11:23 am     Reply with quote
Try www.ljcv.net - excellent quality.
Regards, Andrew
SherpaDoug
PostPosted: Wed Mar 09, 2011 6:08 pm     Reply with quote
That looks like it might do the trick. Thanks!
ezflyr
PostPosted: Wed Mar 09, 2011 7:04 pm     Reply with quote
Another alternative might be the PIC-Web boards by Olimex available from Sparkfun.
Here is an example of a board I've played with: http://www.sparkfun.com/products/7829
John
bkamen
PostPosted: Sat Mar 12, 2011 9:52 pm     Reply with quote
Microchip also sells the PICdem.net2.
It has the largest 8bit Ethernet PIC onboard (18F97J60) with also an ENC28j60 so you can switch to that if you want to use a PIC that lacks integrated ethernet.
-Ben
SherpaDoug
PostPosted: Sun Mar 13, 2011 4:30 pm     Reply with quote
Thanks for the ideas guys. This is the first project that will require me to go beyond my comfort zone with RS232 into a more modern interface.
I just got the book TCP/IP Lean and have ordered the CCS embedded Ethernet development kit. Are there any other references you can reccomend?
I foresee a lot of reading in my future.
bkamen
PostPosted: Sun Mar 13, 2011 5:46 pm     Reply with quote
Download the microchip application library and get the most up to date TCPIP stack.
It won't compile under CCS at the moment, but you can get an idea of how they have things working.
The CCS TCPIP stack is actually v3.75 of the Microchip stack.
Currently, Microchip is on (I think) version 5.32.
Give you an idea of what's missing. ;)
-Ben
drx2k
PostPosted: Wed May 04, 2011 8:03 am     Reply with quote
ezflyr wrote:
John
Can you help me how to use this http://www.sparkfun.com/products/765 in CCS C TCPIP Stack?
I get problem in setting configuration in ccstcpip.h and hardware.h
