Changing Soft Uart Baud
Sparky
PostPosted: Sat Mar 05, 2011 6:02 pm     Reply with quote
Is it possible to change a soft uart baud while the program is running? I know there is set_uart_speed() but I believe that only works for the hardware uart.
Thanks.
PostPosted: Sat Mar 05, 2011 6:58 pm     Reply with quote
If you use the 'search' feature here, you should get a couple of hits about setting up 2(or more) use rs232(....) with stream option.
Far easier than the old way of locating the memory location of the baud rate counter and changing it.....!!
PostPosted: Sat Mar 05, 2011 7:53 pm     Reply with quote
See this thread which has sample code by Ttelmah:
http://www.ccsinfo.com/forum/viewtopic.php?t=24090
Sparky
PostPosted: Sun Mar 06, 2011 5:41 am     Reply with quote
Thank you very much for the help.
I am now using 2 streams with different bauds on the same pins and it works perfectly.
