Sending Data Problem at SPI Slave mode
Elysion
PostPosted: Mon Feb 21, 2011 6:12 am     Reply with quote
I wrote these codes shown below but I couldn't send any data at SPI Slave mode. (My compiler version is 4.114) (Also I looked at this link: http://www.ccsinfo.com/forum/viewtopic.php?t=39145&highlight=spi+slave
Master Side
#include <18F14K50.H>
#include <PIC18F14K50_registers.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP, CPUDIV1,NOMCLR
int a;
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
  a=spi_read();
  if(a==58)
  output_high(PIN_C3);
  output_low(PIN_C3);
Slave
int a;
#int_ssp
void ssp_isr(void)
   a=58;
   spi_write(a);
   delay_us(100);
setup_spi(SPI_SLAVE | SPI_SS_DISABLED | SPI_L_TO_H);
clear_interrupt(INT_SSP);
enable_interrupts(INT_SSP);
Could you propose anything? (I tested these codes with real hardware.)
Thanks.
PostPosted: Mon Feb 21, 2011 6:29 am     Reply with quote
Two separate problems.
First, is that you are potentially not sending anything till _after_ the master has completed it's transaction.
With SPI, the master sends a byte to the slave, and gets back garbage (what is left in the slaves transmit buffer from last time). It then has to clock another byte to the slave, to get back what the slave loaded. INT_SSP, only occurs when the slave has received the first byte....
Then second, is that the master has to _clock_ each transaction. Currently you are not.
//Slave
int a;
#int_ssp
void ssp_isr(void)
   int dummy;
   dummy=spi_read(); //get the byte the master has sent - you may want it
   a=58;
   spi_write(a);
//Master
   int a;
       spi_write(0); //send a byte to trigger the SSP interrupt.
       delay_us(40); //Wait for the slave to load the response
       a=spi_read(0); //read the reply _clocking it_. Hence the '0'
       if(a==58)
         output_low(PIN_C3);
Elysion
PostPosted: Tue Feb 22, 2011 8:55 am     Reply with quote
Ok Thanks for your consideration. It is worked. But when I added RS232 module to these codes, it didn't work.
My slave side is same but I added 2 lines to master side:
#use rs232(baud=9600, xmit=PIN_B7,rcv=PIN_B5)
   int a;
       a=spi_read(); //read the reply _clocking it_. Hence the '0'
         if(a==58)
         printf("It is worked");
         output_low(PIN_C3);
PostPosted: Tue Feb 22, 2011 1:00 pm     Reply with quote
if(a==58)
You took out the 0 parameter on the spi_read() function (but you left
in the comment). Why did you do that ? Now the Master won't make the
SCLK signal. Without the SCLK, it won't read the byte from the slave.
It won't work.
Elysion
PostPosted: Thu Feb 24, 2011 2:18 am     Reply with quote
Ttelmah codes didn't work and I changed this line "a=spi_read(0); " and It is worked. But I couldn't solve RS232 problem,yet
PostPosted: Thu Feb 24, 2011 4:01 am     Reply with quote
Had you taken the time delay out of the slave code. It won't work if that is there.
What you are doing at present, is the read, without '0', returns the 'garbage' value that was clocked when you sent the command to the master. Because the code loops, you will on the second loop, get back the value from the first command. No good if the value is changing, but will 'appear' to work, with the code just returning one value.
