david90
| Software Uart and External Interrupt issue |
Posted: Sun Feb 20, 2011 4:48 pm |
| Code: | //tested code with dev board.
#include <12F683.h>
#device adc=8
#FUSES INTRC //Internal RC Osc
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=8000000)
#use rs232(baud=2400,parity=N,xmit=PIN_A1,rcv=PIN_A2,bits=8,errors)
int buffer[10];
int i=0;
int open_detected=0;
int close_detected=0;
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ);
enable_interrupts(INT_EXT);
ext_int_edge( H_TO_L );
enable_interrupts(GLOBAL); //enable interrupt
output_high(PIN_A5);
output_low(PIN_A5);
if (open_detected==1)
output_high(PIN_A0);
output_low(PIN_A0);
output_low(PIN_A0);
open_detected=0;
if (close_detected==1)
output_low(PIN_A0);
close_detected=0;
#INT_EXT //use external pin int to avoid polling for serial data. Software UART does not have INT.
void INT_EXT_handler() {
shift_left(buffer,10,0);
buffer[0]=getc();
if ((buffer[0]==0x57 && buffer[1]==0xA9) || (buffer[0]==0x5F && buffer[1]==0xA1))
open_detected=1;
if (buffer[0]==0xDF && buffer[1]==0x21)
close_detected=1;
Whenever I power on my PIC, it immediately goes into the INT_EXT ISR and get stuck there until I send serial data to the PIC. I know for a fact that when I power up my pic, the pic doesn't even go to my infinite while loop but instead goes directly to the ISR. Why does this happen? There might be a chance that this happens because of my dev board. |
Joined: 01 Jul 2010 Posts: 9643 Location: Greensville,Ontario
Posted: Sun Feb 20, 2011 4:57 pm |
You might want to enable the PowerUpTimer ( PUT) as well as and a small delay in Main before the interrupts are enabled.
Depending on the board layout, power supply specs, etc. you might already have an interrupt from something 'glitchy'. |
Posted: Mon Feb 21, 2011 12:36 am |
| Quote: |
Read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=43138
| Quote: |
Why do this ? Just use a pointer or an array index.
If you change this fuse to INTRC_IO then you can also use PIN_A4
as an i/o pin. |
