cerr
Joined: 10 Feb 2011 Posts: 241 Location: Vancouver, BC
| delay |
Posted: Wed Feb 16, 2011 1:36 pm |
I'm very new to using CCS and in fact this is my first day utilizing it.
I loaded the led flash application but it seems like my delay is 10 times to slow e.g. 100ms delay is giving me in fact a 1second pulse...
I do use a 10MHz crystal (the one that comes on the PIC18 explorer board from Microchip).
I don't understand as I'm not using any kind of prescaler or something.
The code:
#include <18F8722.h>
#device ICD=TRUE
#device adc=16
#FUSES LP //Low power osc < 200 khz
#FUSES BBSIZ1K //1K words Boot Block size
#use delay(clock=10000000)
#define LED PIN_D0
#define DELAY 100
//Example blinking LED program
while(true){
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
Thanks for hints!  |
Posted: Wed Feb 16, 2011 1:43 pm |
| Quote: | #FUSES LP //Low power osc < 200 khz
Look in the PIC data sheet, in the oscillator section, to see the correct
fuse setting for a 10 MHz crystal. |
cerr
Posted: Wed Feb 16, 2011 1:59 pm |
| PCM programmer wrote: | | Quote: | #FUSES LP //Low power osc < 200 khz
Exactly, that did the trick,
Thank you bud, for that hint! |
