problem with A/D
Goto page Previous  1, 2, 3, 4
PostPosted: Thu Feb 10, 2011 12:05 pm     Reply with quote
CCS doesn't have a 'function', you have to create your own.
PostPosted: Thu Feb 10, 2011 12:46 pm     Reply with quote
How to make code that have initial value for port analog a0, then when
port a0 change make led bright?
Examples of how to read the ADC and change the brightness of the
LED based on the analog voltage level:
http://www.ccsinfo.com/forum/viewtopic.php?t=40007
http://www.ccsinfo.com/forum/viewtopic.php?t=40222&start=1
Example of how to read the ADC and turn an LED on or off,
depending on the value of the analog voltage level:
http://www.ccsinfo.com/forum/viewtopic.php?t=42952&start=1
If you have problems, please start a new thread for your problem
instead of putting unrelated posts on to this old thread.
Mamat
View user's profile Send private message Yahoo Messenger ICQ Number
http://www.ccsinfo.com/forum/posting.php?mode=reply&t=32
PostPosted: Thu Feb 10, 2011 10:21 pm     Reply with quote
I'm sorry. I not mean function but how to write coding.
#include <16F877.H>
#device adc=8
#define LED_PIN  PIN_B0
int8 adc_result;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
float new;
new=adc_result;
output_low(LED_PIN); // Set LED to Off
   adc_result = read_adc();
   if(adc_result !=new)
      output_high(LED_PIN);
      adc_result=new;
This code I want to use for ldr that connect to pic pin_a0. I assume initial intensity light 1volt, suddenly intensity light change to 2volt. Led light 1minute. So 2volt will be current ref intensity. It always change. This project for movement detector. This using ne555 but I want using pic for more efficient.
http://www.electro-tech-online.com/attachments/general-electronics-chat/22685d1222869801-triggering-555-timer-ldr-circuit-2.gif
SherpaDoug
PostPosted: Fri Feb 11, 2011 7:15 am     Reply with quote
Due to natural noise the value from the A/D will always be different. You need to decide on a threshold where the light level is "significantly" different. Subtract the new light level from the old light level. If the difference is small, positive or negative, then the light did not change significantly. If the difference is bigger then you trigger your LED.
Note that artificial lights tend to flicker at 50Hz or 60Hz depending on where you are. You may have to find a way to ignore this flicker.
Page 4 of 4
