Timer0 Counter Problem
bells_electronics
PostPosted: Fri Feb 04, 2011 9:54 am     Reply with quote
hey guys,
I need to use timer0 as a counter to count pulses. After counting 100,000 or > pluses it should give one high pulse on PortC_0,
now I'm not able to get proper results.
#include <16F876A.h>
#FUSES NOWDT, HS, PUT, PROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD
#use delay(clock=20MHz , crystal)
unsigned int32 x,y;
#int_timer2
void timer2_isr(void)
    x = GET_TIMER0();
    set_timer0(0);
    y=y+x;
  x=0;
  y=0;
  set_tris_c (0x00);
  set_timer0(0);
  setup_timer_0(RTCC_DIV_1 | RTCC_EXT_L_TO_H );
  setup_timer_2(T2_DIV_BY_1, 249, 16);
   if(y>100000)
     y=0;
     output_high(PIN_C0);
     output_low(PIN_C0);
PostPosted: Fri Feb 04, 2011 10:55 am     Reply with quote
Currently, C0, is basically going to be high all the time, except for dropping for two instruction times every half second.
If the count gets to > 100000, it'll stay high for one second, without the two instruction time low pulse.
Get rid of the second 'output_high', and then you might see the 'high pulse'.
_But_ you really need to disable interrupts, copy the y value into a 'local' variable, re-enable the interrupts, and do a test on this local value, or you may well get 'spurious' results if the value updated during the test.
How fast are the pulse likely to be?. T0, on the 876, is only an 8bit counter. T2, interrupts every 4000 instructions, so every 0.8mSec. If pulses arrive faster than every 3.125uSec, T0, will wrap, before the T2 interrupt. Also remember that a count can be missed between reading the timer value, and clearing the timer.
You'd probably be better to use timer1, and just increment a 17th bit value when this interrupts, rather than using T2, and T0.
bells_electronics
PostPosted: Fri Feb 04, 2011 12:28 pm     Reply with quote
Sir I'm asked to use only timer0, I can't use timer1.
unsigned int32 x,y;
  x=0;
  y=0;
  set_tris_c (0x00);
  set_timer0(0);
   x = GET_TIMER0();
    set_timer0(0);
    y=y+x;
   if(y>100000)
     y=0;
     output_low(PIN_C0);
