vinniewryan
| rs-232 not accepting data |
Posted: Mon Jan 31, 2011 6:47 pm |
I'm having a strange problem with the rs-232 communication in my program. The xmit pin is sending data to a 19,200 baud serial LCD, and the rcv pin is receiving data from a 2400 baud RF receiver. The problem is, var always equals 0. I can't get it to accept any serial data correctly. Is my rs-232 set up correctly?
#include "16f684.h"
#device ADC=10
#Fuses NOFCMEN,NOPROTECT,MCLR,NOBROWNOUT,NOCPD,NOPUT,NOIESO,INTRC_IO,NOWDT
#use rs232(baud=2400,rcv=PIN_a4,force_sw, bits=8)
#use rs232(baud=19200,invert,long_data,force_sw,xmit=pin_a0)
unsigned int8 command=0;
int8 var=0;
int8 state=0;
if(state==0)
if(!kbhit())
var=getc();
delay_ms(5);
state=1;
if(state==1)
command=12; //clear and return home
putc(command);
printf("var=%d", var);
delay_ms(20);
state=0;
_________________ Vinnie Ryan |
vinniewryan
Posted: Mon Jan 31, 2011 7:25 pm |
Nevermind, I figured it out. I had to put the #use(rs-232) statements before each rs-232 function, like this:
#include "16f684.h"
#device ADC=10
int8 var=0;
int8 state=0;
if(state==0)
if(!kbhit())
var=getc();
delay_ms(5);
state=1;
if(state==1)
putc(command);
delay_ms(20);
state=0;
Posted: Mon Jan 31, 2011 7:42 pm |
It would be better to define each #use rs232() statement with a Stream
parameter, and then use fgetc(), fputc, etc., and specify the desired
stream in each statement. Then the #use rs232() statements can be
placed at the top of your program again. This is described in the CCS
manual. |
vinniewryan
Posted: Mon Jan 31, 2011 8:35 pm |
I found that out today and am using STREAM now, it's much cleaner this way.
Cheers! _________________ Vinnie Ryan |
