Does the PIC16f877a's UART buffer flooded? Need help.
xyzsor
PostPosted: Mon Jan 31, 2011 12:44 am     Reply with quote
Good morning everyone. I have a little problem that I need help with.
I connected my PIC16f877a to a PC via UART.
I could send data and the PIC would receive it.
However I notice if the PIC is not reading the data being sent (example it is doing a sequence) and the UART of the pic, gets flooded with data. The pic's program hangs up or something like that.
Example I send the data
"?H???A?XYZ??Sd,v??!??3|?Ad?A?XYZa?Saja"
What I want to happen is that when the pic receives an XYZ data it would start a running lights sequence.
Heres my code.
#include <16F877A.h>
#device adc=8
#FUSES NOWDT      //No Watch Dog Timer
#FUSES XT         //Highspeed Osc > 4mhz
#FUSES PUT        //Power Up Timer
#FUSES NOPROTECT  //Code not protected from reading
#FUSES NODEBUG    //No Debug mode for ICD
#FUSES NOLVP      //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD      //No EE protection
#use delay(clock=4000000)             // Sets crystal oscillator at 20 megahertz
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7) //Sets up serial port output pin & baud rate
#byte portb=6                /* defines memory location of register */
//declare variables
  int8 data[10];
  byte c,d;
  set_tris_b(0x00);
//test if pic is working
      portb = 0xFF;
      portb = 0x00;
      portb = 0xFF;
      portb = 0x00;
//wait for passphrase
   while (true)
       data[0] = getc();
         if (data[0]=='X')
            portb = 0x01;
again:
            data[1] = getc();
            if (data[1]=='X')
               goto again;
            if (data[1]=='Y')
                  portb = 0x03;
                   data[2] = getc();
                     if (data[2]=='Z')
//start a running lights pattern
                           c = 0;                   /*initialize the count c equal to zero */
                             d = 0x01;              /* assigns the content of d to 0x01 */
                             while(c<8) {
                                  portb = d;        /*sends content of d to portb to turn-on the first LED*/
                                  delay_ms(80);  /* creates half second delay between LED on/off*/
                                  d = d << 1;       /* shifts the value of data to the left by 1 using                                                shift left operator(<<) */
                                  c++;                /* increments the value of c by 1*/
      portb = 0x55;
It works well if I sent data when the pic is just reading or waiting for the XYZ during the getc() part.
But if I send a stream of data while the pic is doing a running lights sequence, the PIC would hang up.
Whats wrong? Does the PIC get flooded? Is there a way to clear the PICS UART buffer before starting the getc() again?
Thanks in advance to everyone who helps.
PostPosted: Mon Jan 31, 2011 3:33 am     Reply with quote
ERRORS......
Last answered on Saturday, in the thread 'continuous serial reception'.
Do a search.
xyzsor
PostPosted: Mon Jan 31, 2011 9:23 am     Reply with quote
Ttelmah wrote:
ERRORS......
Do a search.
Nice!.. Thanks a lot.. just one word, fixed it all.. Errors.. Again thanks...
