16f882 ECCP problem
Elysion
16f882 ECCP problem
PostPosted: Thu Jan 20, 2011 6:13 am     Reply with quote
I used these codes shown below, but I couldn't use 16f882's half bridge module. Could you propose anything for this operation?
#include <16f882.h>
#include <PIC16F882_registers.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=20000000)
#use fast_io(c)
   set_tris_c(0x00);                 // set PORTC as output
   output_C(0x00);
   T2CON=0b00000100;
   PR2=4;
   CCP1CON=0b10001100;
   CCPR1L= 0b00000010;
   PWM1CON=0b10000001;
PostPosted: Thu Jan 20, 2011 11:53 am     Reply with quote
What's your compiler version ?
Elysion
PostPosted: Fri Jan 21, 2011 2:38 am     Reply with quote
my compiler version is 4.108
Elysion
PostPosted: Sat Jan 22, 2011 1:29 am     Reply with quote
And I want to get 1MHZ PWM at the output of the PWM. But I couldn't. Is there anyone to answer my question?
Thanks.
PostPosted: Sat Jan 22, 2011 2:28 am     Reply with quote
I'm sorry. I forgot to work on your problem during the day. I'll try to
give you an answer now, but I can't test it in hardware so I don't
guarantee this will work.
In Half-Bridge mode, the PWM signals come out on PWM pins P1A and P1B
which are pins C2 and B2 in the 16F882. So look on those pins for the
signals. In addition to this, vs. 4.108 has a bug, where is doesn't setup
pin P1B (B2) correctly as a output pin. So I've added a line of code to
do this manually.
I think I've setup Timer2 to give you a 1 MHz PWM frequency.
For the duty cycle, you will need to use an 'int16' value to get
the maximum number of resolution steps at this frequency.
If you use a constant for the duty cycle, you need to append an 'L'
on it as I have shown below. This will invoke 10-bit PWM mode.
If you use a variable for the duty cycle, declare it as an 'int16'.
Here's the example. As I said, I can't test this in hardware at the
moment.
#include <16F882.H>
#define P1B PIN_B2
setup_ccp1(CCP_PWM_HALF_BRIDGE | CCP_PWM_H_H);
setup_timer_2(T2_DIV_BY_1, 4, 1);
output_low(P1B);  // Initialize P1B to the inactive state (low)
set_pwm1_duty(10L); // 50% duty cycle
Elysion
PostPosted: Sat Jan 22, 2011 3:12 am     Reply with quote
I tried these codes in real hardware. But the frequency of PWM is 200khz not 1Mhz. I couldn't get 1 Mhz at the output of PWMs.
PostPosted: Sat Jan 22, 2011 3:17 am     Reply with quote
Do a simple pin toggling test, and verify your chip really is running at 20MHz.
I'd suggest it is really running at 4MHz...
Elysion
PostPosted: Sat Jan 22, 2011 9:17 am     Reply with quote
Ok thanks for your help. I solved my problem thanks to you. It is related with the crystal.
