Joined: 01 Jul 2010 Posts: 9641 Location: Greensville,Ontario
| v4.064 include math.h error <solved> |
Posted: Thu Jan 13, 2011 2:01 pm |
Ok, thought I'd try the math.h functions instead of shoveling snow..
compiler version 4.064
math.h is revised 2007
pic PIC16F88
Program, 16f88.h and math.h all in same folder.
Bare bones code( flash led). works 100%.
NOTHING fancy...
if I add the line..
and compile I get 100+ errors,
first one is
*** Error 48 "C:\PCMupdates\picc4064\PICC\Projects\MATH.H" Line 36(9,16): Expecting a (
which seems to point to the first math function...
comment out as follows
//#include <math.h>
Recompile and all is well.
I figure I'm doing something wrong but shouldn't it compile fine, even if I do not call a function from math.h?
Posted: Thu Jan 13, 2011 2:08 pm |
I compiled the test program shown below with vs. 4.064 and go no errors.
CCS PCM C Compiler, Version 4.064, xxxxx 13-Jan-11 12:06
Filename: pcm_test.lst
ROM used: 18 words (0%)
Largest free fragment is 2048
RAM used: 6 (2%) at main() level
6 (2%) worst case
Stack: 0 locations
| Code: | Executing: "C:\Program Files\PICC\Ccsc.exe" +FM "pcm_test.c" +DF +LY -T -A +M -Z +Y=9 +EA -EW #__16F88=TRUE
Memory usage: ROM=0% RAM=2% - 2%
0 Errors, 0 Warnings.
Loaded C:\Program Files\PICC\Projects\PCM_Test\pcm_test.cof.
BUILD SUCCEEDED: Thu Jan 13 12:06:52 2011 |
| Code: | #include <16F88.H>
#include <math.h>
Posted: Thu Jan 13, 2011 2:44 pm |
Hay PCM, appreciate the fast reply!
Ok, I cut and pasted your program into a new project, even changed the compile options to yours...thinking one of mine(defaults) wasn't right but...
..still won't compile...
unless I comment out the include as before
//#include <math.h>
I can open all the files and they appear ok... just copies from the original folders.
Sure is a head scratcher. |
Posted: Thu Jan 13, 2011 2:48 pm |
| Quote: | | just copies from the original folders |
But that is a difference. I'm compiling this code from the original
installation files. The compiler is installed in this directory structure:
| Quote: | c:\program files\picc
c:\program files\picc\drivers
c:\program files\picc\examples
etc. |
My project file is in the same overall directory structure:
| Quote: | | c:\program files\picc\projects\pcm_test\pcm_test.c |
I don't have the CCS files copied to any other place. Are you possibly
mixing files from different versions of the compiler ? That should not
be done.
I suggest you re-install the compiler and build the program from the
original files. |
Posted: Thu Jan 13, 2011 8:53 pm |
Ok, reinstalled, but still same issue....
took a lonnnnng break.
finally tried putting copies of all the files ( .h headers,.inc includes and main.c ) into same folder
compiles fine.....
I would have thought the compiler would have grabbed the picxxx.h from the devices folder, the math.h from the examples folder and the myprogram.c from my projects folder...
oh well....
guess tomorrow I'll see how much ROM log(x) takes up....
... all for a simple thermisitor DTC project to whittle away the winter !
Thanks PCM for the feedback ! |
Posted: Fri Jan 14, 2011 3:40 am |
It does....
It looks in the current directory, and _then_ in the defined directories for the includes etc..
Somewhere your defines in this regard are wrong.
The options are retained from old installs, so if (for instance), you installed once into 'PICC', and then latter into 'PICCNEW', the defines will only be right for one of them, and will need changing if you want to use the other.
If you have the IDE, 'Options', 'Project Options', 'Include Files'.
This can be both useful, and a caveat. Useful, if you want to (say) compiler using 4.099, but with the include files from 4.115. A caveat, if you are using multiple versions, and lose track of which includes you are actually using.....
Posted: Fri Jan 14, 2011 7:19 am |
Well it just got more interesting ! During the compile, I actually got to read the compiler title screen info(takes a few seconds for the math.h stuff..) and it says I'm using V4.025 ! Not the 4.064 I thought I was using....
Looks like I'm going to have to do some major 'house cleaning' on this XP machine as I 'thought' I was smart having versions in their own folders...projects in their own folders,etc.
I'll try a superclean install with defaults and try to start over.
First,brew another pot of java... |
