undefined identifier byte
skoberlink
PostPosted: Mon Jan 10, 2011 11:15 am     Reply with quote
I'm using the ccs built-in sqrt to calculate the square root of a float. It gives me a linker error that there is an undefined identifier BYTE. Since it's a builtin I wouldn't expect this to be an issue. Also I have properly included the math.h library. This problem occurs in the sqrt function. I'm not really sure how to fix it. Any suggestions or has anyone had similar problems?
PostPosted: Mon Jan 10, 2011 12:47 pm     Reply with quote
you'll have to show us a small,compiliable program with headers for us to help you.....also need compiler version !
PostPosted: Mon Jan 10, 2011 1:14 pm     Reply with quote
BYTE isn't a CCS C built-in data type. You have to define it.
PostPosted: Mon Jan 10, 2011 1:20 pm     Reply with quote
It's in the .h file for every PIC.
16F877.h
////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int8
#define BOOLEAN int1
