isikmurat06
| i2c problem |
Posted: Sat Jan 08, 2011 8:11 am |
hi,
I wanna communucate 3 pic with eacother.
One of them must be master and the others must be slave.
The LCD that is connected to slave pic doesn't show anything.
Please help....
I use this code for master pic;
#use i2c(master,sda=pin_c4,scl=pin_c3,fast=400000)
i.2c_start();
i2c_write(0x01); // slave pic address
i2c_write(data);
i2c_stop();
I use this code for slave pic;
#use i2c(slave,sda=pin_c4,scl=pin_c3,fast=400000,address=0x01,FORCE_HW)
#INT_SSP
int I2C_kesme()
int data;
disable_interrupts(INT_SSP);
i2c_start();
i2c_write(0x01);
data=i2c_read();
delay_ms(11);
i2c_stop();
printf(putc_lcd,"%d",data);
return;
Posted: Sat Jan 08, 2011 9:41 am |
'1' is not a legitimate I2C address. The first few addresses are _reserved_, and an address number will always be _even_. The low bit of an I2C address is the 'direction' flag. You are sending a command to read from reserved device 0.
Posted: Sat Jan 08, 2011 10:21 am |
Also, understand, that the _master_ controls all transactions. Only it can send a start or a stop.
Joined: 01 Jul 2010 Posts: 9637 Location: Greensville,Ontario
Posted: Sat Jan 08, 2011 12:32 pm |
| Also be sure to add pullups on the I2C lines ! 4K7r I think.... |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
Posted: Sat Jan 08, 2011 2:45 pm |
| temtronic wrote: | | Also be sure to add pullups on the I2C lines ! 4K7r I think.... |
1K for 400KHz, 4K7 for 100KHz _________________ Regards, Andrew
isikmurat06
Posted: Sun Jan 09, 2011 8:42 am |
| thanks you all for your answer. I will try and share the results. |
