PCD: RTOS is not working with CCS 4.114
kongfu1
PostPosted: Sun Jan 02, 2011 10:36 pm     Reply with quote
I have used two different PC24 chips to test RTOS features. It is very simple test which toggles a few LED's in a thread. Without RTOS, it works fine. As soon as RTOS enabled, nothing works. Please correct me if any mistake in my testing code.
I read a few posts a year ago about RTOS and PCD compiler. I am wondering if RTOS has been fixed or not.
Howard
//#include <24FJ256GB206.h>
#include <24FJ128GA010.h>
#define OS_ON
#ifdef OS_ON
#use rtos(timer=1,minor_cycle=100ms)
#task(rate=1000ms,max=100ms)
void Report_rtos_task (  );
#endif
void IOTest(void)
   output_toggle(PIN_A0);
   output_toggle(PIN_A1);
   output_toggle(PIN_A2);
   output_toggle(PIN_A3);
   output_toggle(PIN_A4);
   output_toggle(PIN_A5);
   output_toggle(PIN_A6);
   output_toggle(PIN_A7);
   IOTest();
   rtos_run ( );
     //IOTest();
FvM
PostPosted: Mon Jan 03, 2011 5:44 am     Reply with quote
With all PCD versions up to V4.116, I get "Internal Error - Contact CCS. Built-in call fail, rtos run".
kongfu1
How do you see the
PostPosted: Mon Jan 03, 2011 10:39 am     Reply with quote
How do you see the "Internal Error" reported by using ICD or SIM?
Thanks,
Howard
FvM
PostPosted: Mon Jan 03, 2011 10:45 am     Reply with quote
The code already doesn't compile.
kongfu1
PostPosted: Mon Jan 03, 2011 11:36 am     Reply with quote
FvM,
OK. I have no problem to compile the code with version 4.114. Hex file was generated but is not executable.
bkamen
PostPosted: Mon Jan 03, 2011 2:30 pm     Reply with quote
I can validate -- 4.116 fails the compile.
*** Error 44 "rtos-test.c" Line 33(176,177): Internal Error - Contact CCS  Built in call fail, rtos_run
PostPosted: Mon Jan 03, 2011 2:54 pm     Reply with quote
This is the second thing reported in the last couple of weeks, where stuff compiles on some machines and not others. The last was the malloc example, which compiled OK for me, but several other users reported it not compiling after about 4.110, without changes....
It looks like CCS has found another 'secret fault' somewhere in the compile process....
kongfu1
Rtos is fixed
PostPosted: Mon Jan 03, 2011 9:11 pm     Reply with quote
CCS sends me another PCD.dll (version 4.117).
RTOS is working now.
FvM
PostPosted: Thu Jan 06, 2011 5:21 am     Reply with quote
Regarding secret faults, the behaviour can be possibly explained for a computer with multiple CCS C installations. In the IDE, everything is loaded from the current CCS application directory, except for drivers and include files, that are read from the the default CCS directory (or the directory, where CCS C has been installed last).
bkamen
PostPosted: Thu Jan 06, 2011 12:22 pm     Reply with quote
I don't use the IDE...
I typically compile from IDM's fabulous UltraEdit32 or MPLAB.
So hopefully I'm spared those maladies.
-Ben
kongfu1
PostPosted: Thu Jan 06, 2011 4:04 pm     Reply with quote
-Ben
I am using MPLAB with two different versions of PCD. Everythings works fine now.
