PIC16f877A and timer0
Goto page 1, 2, 3, 4  Next
wind88
PostPosted: Wed Dec 29, 2010 9:07 am     Reply with quote
I am using pic16f877a and timer0 to control the output to servo motor from ldr.
#include <16F877A.h>
#device adc=8
#include <math.h>
#include <stdlib.h>
#FUSES NOPUT                    //No Power Up Timer
#define MAX_VALUE 200
#define CCW_ROTATION MAX_VALUE - 20
#define CW_ROTATION MAX_VALUE - 10
#define STOP_ROTATION MAX_VALUE
#define THRESHOLD_VALUE 50
#bit  ADFM_BIT = 0x9F.7
#define A0 PIN_a0
#define A1 PIN_a2
#define C1 PIN_C2
unsigned char pulse_max=0;
unsigned char pulse_top=0;
unsigned char top_value = 0;
void isr(VOID)
  if(INT_TIMER0) {               // TIMER0 Interrupt Flag
    pulse_max++;            // Pulse Max Increment
    pulse_top++;            // Pulse Top Increment
    /* MAX_VALUE=200 turn off the pulse */
    if (pulse_max >= MAX_VALUE) {
      pulse_max=0;
      pulse_top=0;
      output_low(C1);                // Turn off RC1
    if (pulse_top == top_value) {
      output_high(C1);                // Turn On RC2
    set_timer0(48) ;             // Initial Value for 0.1ms Interrupt
    clear_interrupt(int_timer0);          // Clear TIMER0 interrupt flag
  unsigned char ldr_left;
  unsigned char ldr_right;
  int ldr_diff;
  /* Initial Port Used */
   setup_adc_ports(ALL_ANALOG);     // SETTING ADC CHANNEL // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd
   setup_adc(ADC_CLOCK_DIV_2);
     output_C (0x00);
  /* Init Servo Pulse */
  pulse_max=0;
  pulse_top=0;
  top_value = MAX_VALUE; // top_value = MAX_VALUE: Servo Motor Stop
  /* Init TIMER0: Period: Fosc/4 x Prescaler x TMR0*/
set_timer0(0) ;
    /* Read the ADC here */
   set_adc_channel(0);
   while ( input(A0) ) {
   delay_ms( 400 );
   ldr_left=read_adc();
   set_adc_channel(1);
   while ( input(A1) ) {
   delay_ms( 400 );
   ldr_right=read_adc();
    /* Get the different */
    ldr_diff=ldr_left - ldr_right;
    if ((ldr_diff >= -THRESHOLD_VALUE) && (ldr_diff <= THRESHOLD_VALUE)) {
      top_value = MAX_VALUE;     // Stop the Servo Motor
    } else {
      if (ldr_diff > THRESHOLD_VALUE) {
        top_value = CCW_ROTATION;  // Counterclockwise Rotation
      } else {
        top_value = CW_ROTATION;   // Clockwise Rotation
This is the code that I have. I already try to search the code in this forum and correct the mistake that I made before. But the code is not functioning in my circuit.
Port AN0 and AN1 is the input for the ldr.
Port RC1 is the output to the servo motor.
PostPosted: Wed Dec 29, 2010 10:52 am     Reply with quote
Without looking very hard:
Nowhere are you enabling the timer0 interrupt.
Nowhere are you telling the compiler that you 'isr' is for the timer0 interrupt.
If input(PIN_A0), and input(PIN_A2) both are false, the code will drop off the end.
Nowhere are you specifying the oscillator for your clock (XT? if you are using a crystal).
Your first 'while' statement will continuously execute the next line, selecting the adc channel, and never proceed to the latter code....
It is not going to work...
Learn to make your code 'tidy' - indent, and some of these faults will become 'self showing'...
wind88
PostPosted: Thu Dec 30, 2010 1:31 pm     Reply with quote
thanx you Smile
I manage to change the code and the error that you told me.
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#define A0 PIN_a0
#define A1 PIN_a2
#define C1 PIN_C2
unsigned int8 ldr_left;
unsigned int8 ldr_right;
unsigned int ldr_diff;
#int_TIMER0
void  TIMER0_isr(void)
    pulse_max=0;
    pulse_top=0;
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
  pulse_max=0;
  pulse_top=0;
set_timer0(206) ;
   set_adc_channel(0);
if ( input(A0) ) {
   delay_ms( 400 );
   set_adc_channel(1);
if ( input(A1) ) {
   delay_ms( 400 );
    } else {
      } else {
PostPosted: Thu Dec 30, 2010 4:34 pm     Reply with quote
So, you have a 4MHz crystal attached?.
Is 'HS' the right oscillator for this?.
You have not corrected the while statement.
     statement()
   code
executes 'statement' continuously, and will _never_ get to 'code'....
wind88
PostPosted: Thu Dec 30, 2010 10:36 pm     Reply with quote
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
  #include <math.h>
  #include <stdio.h>
  #include <stdlib.h>
#define A0 PIN_a0
#define A1 PIN_a2
#define B1 PIN_B1
#define ADFM = 0;      //1 for ADC result to be right-justified, 0 for left-justified
#int_TIMER0
    pulse_max=0;
    pulse_top=0;
    output_low(B1);                // Turn off RC1
    output_high(B1);                // Turn On RC2
    set_timer0(206) ;             // Initial Value for 0.1ms Interrupt
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
  pulse_max=0;
  pulse_top=0;
set_timer0(206) ; //interrupt every 0.1ms
while(1){
if ( input(A0) ) {
  set_adc_channel(0);
   delay_ms( 400 );
if ( input(A1) ) {
   set_adc_channel(1);
   delay_ms( 400 );
    } else {
      } else {
This is the code with a { after the while, is this correct?
wind88
PostPosted: Fri Dec 31, 2010 2:35 am     Reply with quote
Btw, do I need to initialize port A and C first?
How do I initialize to the value that I want? Thanks.
wind88
PostPosted: Fri Dec 31, 2010 9:47 am     Reply with quote
     statement()
   code
regarding the amendment of the code.is it still ok?as i stil get condition is always true in the warning bar.
i really in this help urgently :(
thanx a lot
jecottrell
PostPosted: Fri Dec 31, 2010 10:27 am     Reply with quote
Here is a quick look at an attempt to 'clean up' your code. It makes it easier to read and easier to see problems.
   setup_adc_ports(NO_ANALOGS);  // Why would you setup NO analogs if you're going to be reading analogs?
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   // Init Servo Pulse
   pulse_max=0;
   pulse_top=0;
   // Init TIMER0: Period: Fosc/4 x Prescaler x TMR0
   // No ADC Clock?
   while(true)
      // Read the ADC here
      if ( input(A0) )
         set_adc_channel(0);
         delay_ms( 400 );  // I forget what the delay time required is, but 400mS sounds too long.
      if ( input(A1) )
         set_adc_channel(1);
         delay_ms( 400 );
      // Get the different
      ldr_diff = ldr_left - ldr_right;
Read up on how to configure and read ADC values. There's got to be plenty of threads with the details.
You change back and forth on pins and clock fuse settings between your posted code.
What specific problems are you having? Won't compile? Run time results not what expected?
wind88
PostPosted: Fri Dec 31, 2010 11:40 am     Reply with quote
#device adc=8
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#define A0 PIN_a0
#define A1 PIN_a2
#define B1 PIN_B1
#int_TIMER0
static void TIMER0_isr(void)
if(INT_TIMER0)// TIMER0 Interrupt Flag
pulse_max=0;
pulse_top=0;
output_low(B1); // Turn off RB1
else if (pulse_top == top_value) {
output_high(B1); // Turn On RB1
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
setup_vref(FALSE);
// Init Servo Pulse
pulse_max=0;
pulse_top=0;
enable_interrupts(int_timer1);
while(true)
if ( input(A0) )
set_adc_channel(0);
delay_us( 0.5 );
if ( input(A1) )
set_adc_channel(1);
delay_us( 0.5 );
thanx for replying,
my problems
one of the line in red have a warning that say the condition is always true :(
besides this,the code is not functioning.i m not sure if there is anything wrong from the code
for the TOSC herehttp://pic-c.ccsinfo.com/forum/viewtopic.php?t=44181&highlight=adc
the delay should be 500ns
jecottrell
PostPosted: Fri Dec 31, 2010 12:15 pm     Reply with quote
You don't need to check for the interrupt bit in the ISR. That bit is what triggers the ISR in the first place. So, of course, it will always be true.
You don't need to clear the interrupt flag in the ISR, the compiler handles that with the ISR call.
#int_TIMER0
  // MAX_VALUE=200 turn off the pulse
    pulse_max=0;
    pulse_top=0;
I would suggest getting parts of your code working and then combine the working parts. Do you have any output you could use for debugging, like an LCD or an LED?
wind88
PostPosted: Fri Dec 31, 2010 12:38 pm     Reply with quote
Yup. I do have.
A servo so that it could rotate left or right.
jecottrell
PostPosted: Fri Dec 31, 2010 1:17 pm     Reply with quote
I would start from the very beginning with a new set of code. The goal is to build up the code piece by piece, checking each addition along the way. And you can use the servos to verify your code is working along the way.
So, the first step would be to write two functions, one to pulse left and one to pulse right. Make them pulse different distances or times, so you can ensure that right is actually right and left is actually left.
Write those functions and put them in the main() while(true) loop like this:
while(true)
   pulse_left();
   pulse_right();
Once that is done and you've confirmed that everything is working you can build and test the next section of code, maybe the ISR.
wind88
PostPosted: Fri Dec 31, 2010 9:58 pm     Reply with quote
#include <pic.h>                  // this sample code is using 16F877A !!
//   configuration
__CONFIG ( 0x3F32 );            //configuration for the  microcontroller
//   define
#define servo   RB1
#define   MHZ   *1000L            /* number of kHz in a MHz */
#define   KHZ   *1               /* number of kHz in a kHz */
// Value x must not more that 255
#define   DelayUs(x)   { unsigned char _dcnt; \
           _dcnt = (((x)*(20MHZ))/(24MHZ))|1; \
           while(--_dcnt != 0) \
              continue; \
           _dcnt = (((x)*    (20MHZ))/(24MHZ))|1; \
              continue; }
//   function                   (every function must have a function prototype)
void DelayMs(unsigned char y);    // Value y must not more that 255
                           // delay ms
//   main function               (main fucntion of the program)
   unsigned int i,a;
   //set IO port for servo pin
   TRISB = 0b00000001;         //servo motor is RB1
   PORTB = 0b00000000;         //clear port B
                        //servo will loop infinity
   while(1)               //from one position to another position
      //Delay determine the servo motors position
      //Try change the value for different position
      //Value in DelayUs and DelayMs function must not more than 255
      //Otherwise the timing will not accurate!!
      for(i=0;i<50;i++)      //continues pulse for 50 times
         servo=1;         //set servo pin high
         DelayUs(250);
         DelayUs(250);
         DelayUs(200);      //delay   250+250+200= 700us = 0.7ms
                        //These delay only valid using 20MHz!
         servo=0;         //set servo pin low
         DelayMs(19);      //remain --> 20ms-0.7ms=19.3ms
         DelayUs(250);
         DelayUs(50);      //19ms+0.250ms+0.050ms=19.3ms
      //  _                   _                  _
      // | |                  | |                | |                 ~~50 times
      // | |_________________| |________________| |____________________
      // 0.7ms    19ms      0.7ms      19ms     0.7ms   19ms
      // |<-------20ms------>|
         DelayMs(2);         //delay   2ms
         DelayMs(18);      //delay 18ms
      //  ___                   ___                 ___
      // |   |_______________|   |_______________|   |____________________
      //  2ms       18ms      2ms      18ms       2ms      18ms
//subroutine
   unsigned char   i;
   do {
      i = 4;
      do {
         DelayUs(250);
      } while(--i);
   } while(--y);
This is the code that was supply by the manufacturer to control the servo motor. This code is working with my servo. It can turn left and right.
wind88
PostPosted: Sat Jan 01, 2011 9:01 am     Reply with quote
#device adc=8
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#define A0 PIN_a0
#define A1 PIN_a1
#define B1 PIN_B1
int8 ldr_diff;
static void interrupt_isr(void)
    pulse_max=0;
    pulse_top=0;
   int1 done1;
   int1 done2;
   port_b_pullups(TRUE);
   setup_vref(FALSE);
// Init Servo Pulse
   pulse_max=0;
   pulse_top=0;
   enable_interrupts(int_timer0);
for(;;){
A0;
         set_adc_channel(0);
         read_adc(ADC_READ_ONLY);
         done1 = adc_done();
         while(!done1) {
         done1 = adc_done();
         ldr_left=read_adc(ADC_READ_ONLY);
         delay_us( 30 );
 A1;
         set_adc_channel(1);
         done2 = adc_done();
         while(!done2) {
         done2 = adc_done();
         ldr_right=read_adc(ADC_READ_ONLY);
         delay_us( 30 );
I try to change a lot of the code but still to no avail :(
wind88
PostPosted: Sun Jan 02, 2011 10:03 am     Reply with quote
pulse_max=0;
pulse_top=0;
Can anyone tell me if there is something wrong in this part? Thanx.
Page 1 of 4
