ex_malloc.c Compile error
altra22
PostPosted: Wed Dec 29, 2010 4:53 am     Reply with quote
when i try to compile ex_malloc.c from examples i get errors
Line 72(27,31): Undefined identifier cell
Line 87(44,48): Undefined identifier cell
my compiler version 4.105
PostPosted: Wed Dec 29, 2010 8:15 am     Reply with quote
Er.
It is defined just a dozen lines before in the example.
'struct Cell'
Compiles 'as is' for me, with your version.
altra22
PostPosted: Wed Dec 29, 2010 10:22 am     Reply with quote
I know because of that i wrote this post
to see if the problem with my compiler or the version it self?
i did compile the example file 'as-is' with these errors.
PostPosted: Wed Dec 29, 2010 12:59 pm     Reply with quote
FWIW, Version 4.114 is doing the same thing he is reporting.
The Cell struct is clearly defined right after the includes.
I copied and pasted the ex_malloc.c into a blank project I called test1 and
compiled to get exactly the error he is describing on this line:
beginCell = malloc(sizeof(Cell)); // Allocates memory using malloc()
The word Cell is highlighted in sizeof(Cell)
FvM
PostPosted: Wed Dec 29, 2010 1:42 pm     Reply with quote
Curiously, CCS C requires sizeof(struct Cell) instead of sizeof(Cell) since some V4.09x.
PostPosted: Wed Dec 29, 2010 2:40 pm     Reply with quote
What is odder, is that the version compiles OK for me.
Didn't create a project, just compiled the code 'as is'. Have also tried 4.114, and it too works OK.
It is almost as if the creation of the project alters something, or as if my system has a different setting somewhere.....
