No SPI data from MPL115A1 Pressure Sensor
keplerforever
PostPosted: Sun Dec 26, 2010 12:29 pm     Reply with quote
Hi all,
Although a frequent reader of this forum, I try as much as I can to find myself answers to questions....but this time I'm really stuck.
My goal is to interface my pic 16f877A with the MPL115A1 Pressure Sensor sold by Sparkfun:
http://www.sparkfun.com/products/9721
SPI protocol is used, and I connected the pins as follows:
MPL115A1 SDN - +5V (always power on)
MPL115A1 CSN - PIN_C2
MPL115A1 SDO - PIN_C4 (twisted?)
MPL115A1 SDI - PIN_C5 (twisted?)
MPL115A1 SCK - PIN_C3
MPL115A1 GND - GND
MPL115A1 VDD - +5V
and wrote the following program based on the following example:
http://www.sparkfun.com/datasheets/BreakoutBoards/MPL115A1-ATmega328Code-8-9-10.zip
and on the application note from freesacle:
http://cache.freescale.com/files/sensors/doc/app_note/AN3785.pdf
#include <16f877A.h>
#use delay(clock = 20000000)
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7)
#define CSN_SPI PIN_C2
int8 address, uiTadc, data ;
printf("Start\n\r");
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_64);
output_low(CSN_SPI);
while(1){
   data = 5; //just to be sure that the value is updated
   //Start temperature and pressure conversion
   address = 0x24;
   address &= 0x7F;
   delay_ms(1);
   spi_write(address);
   delay_ms(1);
   spi_write(0x00);
   delay_ms(1);
   output_high(CSN_SPI);
   delay_ms(2);
   // get MSB for Pressure
   address = 0x00;
   address |= 0x80;
   delay_ms(1);
   spi_write(address);
   delay_ms(1);
   data = spi_read(0x00);
   delay_ms(1);
   printf("%u\n\r", data);
   //uiTadc = (unsigned int) data << 8;
   //printf("%u\n\r", uiTadc);
Currently the only value I'm able to see on my RS232 terminal...since 2...weeks is 0.
I've been checking on the scope the signals CSN, SDI and SCK, and they look OK: I can see clock and data transfer. I don't get any answers from SDO line, which explains the 0 on the terminal.
So far I tried the following:
- twisted DO and DI cable
- change the setup values of SPI: div_4, div_16, L_TO_H
- put delays everywhere in the code
- tried different ways for read and write data
I'm out of ideas, so if someone could give me some hints...I would be really thankful.
Regards
Olivier
bkamen
PostPosted: Sun Dec 26, 2010 1:34 pm     Reply with quote
Can you post a graphic/screen shot showing us all the signals?
-Ben
PostPosted: Sun Dec 26, 2010 2:33 pm     Reply with quote
I didn't look too closely at your code but I noticed two things that
are wrong.
You are using SPI mode 2, but the AN3785 says the sensor uses Mode 0.
Figure 11 (on page 13) in the appnote shows that the SPI clock idles at a
low level and samples on the rising edge. This is mode 0. See this diagram:
http://www.totalphase.com/support/kb/10045/#modes
In addition to that, you are initializing the Chip Select line to a low level,
which is the active state. It should be initialized to the In-Active state
which is a high level.
It's much easier to set the correct SPI mode if you use these definitions.
Just add these lines above main() and edit your setup_spi() statement to
use the appropriate mode constant.
// SPI mode definitions.
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Example of revised code:
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_64);
Also, I can't find a spec for it, but it's possible that the sensor requires
a small amount of time for internal initialization. I added a 100 ms
delay above, to allow for this.
keplerforever
PostPosted: Sun Dec 26, 2010 4:54 pm     Reply with quote
Yeahhh!!
Wohohoho!!
You made it PCM, it rocks perfectly now.
Many thanks for your tremendous support.
Olivier
