timer1 interrupt does not fire
gil.fonea@sds-tech.com
PostPosted: Thu Dec 23, 2010 3:36 am     Reply with quote
I am using pic16f882 with ccs PCM 4.077.
My application goes to sleep after finishes task.
Between sleeps (during the task) I need timer1 to fire an interrupt every ~33ms (see my code).
What happens is that the interrupt fires only once before entering sleep in main loop.
Important note: when I replaced the SLEEP() command with while(1); the interrupt fires correctly and I see a ~33ms pulse as expected.
Can you tell me what is wrong with my code?
#INT_TIMER1
void Timer1_ISR()
    set_timer1(0xFFFF);      //every ~33m sec interrupt and recharge timer
    if (temporar == 0)
        output_high (no_connected_RA5);    //pulse to measure timer interval
        temporar = 1;
        output_low (no_connected_RA5);     //pulse to measure timer interval
        temporar = 0;
   BYTE i;
   // set the internal clock to 8MHz ...
   setup_oscillator(OSC_8MHZ);
   setup_timer_1(T1_DIV_BY_1 | T1_INTERNAL);
   INTCON = 0x00; // clear all interrupts
   set_tris_a(0x00);
   port_B_pullups(pin_B0);
   output_float(pin_B0);  //INPUT INT PIN B0
   IOCB = 0x00; // int RB not active
   SETUP_CCP1(CCP_OFF);
   SETUP_CCP2(CCP_OFF);
   SETUP_ADC(ADC_OFF);
   output_low (not_connected_B5);
   output_low (no_connected_RA6);
   output_low (no_connected_RA7);
   CLEAR_INTERRUPT(INT_TIMER1);
   enable_interrupts (INT_TIMER1);
   enable_interrupts (INT_SSP);
   enable_interrupts (GLOBAL);
   #asm  // here interrupt enter !!!
       NOP  //window for interrupt entry
   #endasm
        disable_interrupts (GLOBAL);
      // enter sleep mode
       INTCON = 0xD0;             // enable interrupts
       TMR1ON = 0;
       SLEEP();
       TMR1ON = 1;
       setup_uart(TRUE);
       INTCON = 0x00;            // disable interrupts
Gil F.
PostPosted: Thu Dec 23, 2010 3:50 am     Reply with quote
Study the data sheet.
Section 14.6.1.
Then the second list of numbered items. Number 1. Note the _limitation_ about Timer1. _Is_ your timer operating as an asynchronous counter?....
(Internal clock _stops_ when you sleep)
