Changing format type.
chalukg
PostPosted: Mon Dec 20, 2010 2:43 pm     Reply with quote
Hello again me and again a problem Very Happy
I'm using a graphic lcd and keypad.
I want to show the button which is pushed.
There is
key=read_keypad();
and keypad program is coming as int.
But as you know we have to show as char.
How can I convert them?
bkamen
PostPosted: Mon Dec 20, 2010 4:59 pm     Reply with quote
Let's say your int (we'll call it 'result') is what you pull in from the keypad.
Since it's a 4x4 keypad (I'm making this up) you've wired up 'result' to equal a range of 0-15
If you want to PRINT 0 to 15, you want to convert that to ascii.
The easiest way is to simply do this:
printf("%u", result);
This will print result (which is an unsigned int) anywhere from 0-15.
If you want padded preceding 0's,
printf("%02u", result);
This will print 00-15 (because of the 2).
And that's it.
Easy.
PrintF -- it's your friend.
