9356SPI using other pins
Ringo42
PostPosted: Tue Dec 14, 2010 8:50 am     Reply with quote
I'm trying to use the 9356SPI code but I'm not using the standard SPI pins. How do I configure it?
I thought the line below would do it.
#use spi(DI=EEPROM_DI,DO=EEPROM_DO,CLK=EEPROM_CLK,MODE=2,BITS=8,BAUD=400000)
All I read back is -1, even if I write something different.
Here is all the code in my modified 9356SPI.c
 #define EEPROM_SELECT PIN_B2
 #define EEPROM_DI     PIN_B0
 #define EEPROM_DO     PIN_D7
 #define EEPROM_CLK    PIN_B1
#define EEPROM_ADDRESS BYTE
#define EEPROM_SIZE    256
void init_ext_eeprom() {
   int1 i;
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
   output_low(EEPROM_SELECT);
   i=input(EEPROM_DO);
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
   output_high(EEPROM_SELECT);
   spi_write(0x9);
   spi_write(0x80);
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data) {
   spi_write(0xa);
   spi_write(address);
   spi_write(data);
   delay_ms(11);
BYTE read_ext_eeprom(EEPROM_ADDRESS address) {
   BYTE data;
   spi_write(0x18);
   spi_write(address);
   data=spi_read(0);
   return(data);
Ringo Davis
Ringo42
PostPosted: Tue Dec 14, 2010 9:01 am     Reply with quote
Here is the main code
#include <18f4520.h>
#include "9356spi_vario.c"
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
    int value,address;
    init_ext_eeprom();
    for(address=0;address<255;address++)
        WRITE_EXT_EEPROM( Address, address/2 );
        value=READ_EXT_EEPROM( address ) ;
        printf("address %d = %d\r\n",address,value);
Ringo Davis
Ringo42
PostPosted: Tue Dec 14, 2010 9:48 am     Reply with quote
OK I found the 9356.c code that lets you setup your own pins, so that answers that question, but I still get back only -1's.
Looking at the Data sheet here
http://ww1.microchip.com/downloads/en/DeviceDoc/21794F.pdf
I don't understand the code. I'm using the 93C56B. Maybe that is the problem. The B is a 16 bit part.
Is there something I need to modify for the B part?
Ringo
Ringo Davis
PostPosted: Tue Dec 14, 2010 11:40 am     Reply with quote
Do you have the proper pullup resistors on the I/O lines, if required?
Ringo42
PostPosted: Tue Dec 14, 2010 12:09 pm     Reply with quote
Since the pins on the pic are treated as regular IO, they are driven high and low so there should not be a need for pullups.
Ringo
Ringo Davis
PostPosted: Tue Dec 14, 2010 1:27 pm     Reply with quote
This thread has a software SPI driver for the 93LC56B which can use
any i/o pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=38064
Ringo42
PostPosted: Tue Dec 14, 2010 1:49 pm     Reply with quote
Perfect, Thanks.
Ringo Davis
