Bollo
| PIC18F27J53 missing fuses? |
Posted: Mon Dec 13, 2010 3:40 pm |
I have recently updated my compiler version to 4.114 in order to support a PIC18F27J53. It seems some of the fuses related to the oscillator are somehow missing. I'm attempting to use the internal RC oscillator with the PLL. The fuses are present in the .h file but the compiler does not recognise them:
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FH "main.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 111 "main.c" Line 10(7,30): Unknown keyword in #FUSES "NOCPUDIV"
*** Error 111 "main.c" Line 13(7,30): Unknown keyword in #FUSES "SOSC_HIGH"
*** Error 111 "main.c" Line 29(7,30): Unknown keyword in #FUSES "LS48MHZ"
3 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Mon Dec 13 21:34:10 2010
The lst file generated without the fuses looks like (last part only):
Configuration Fuses:
Word 1: F49E NODEBUG NOXINST NOSTVREN NOWDT NOPROTECT PLL1 PLLEN
Word 2: F702 WDT128 NOFCMEN NOIESO INTRC_PLL_IO NOCLOCKOUT
Word 3: FCFF NOIOL1WAY MSSPMSK7 DSWDT2147483648 DSWDT DSBOR RTCOSC_T1 DSWDTOSC_INT ADC12 PLL
Word 4: F3FF NOWPCFG WPBEG WPDIS WPFP
The oscillator seems to be running very slow.
#use delay(clock=48000000)
setup_oscillator(OSC_PLL_ON);
Are both used. Can anyone help? |
Posted: Mon Dec 13, 2010 3:57 pm |
Post your attempt to make it work. Post a short test program to blink
an LED. Don't include any Wizard code. Example of short but complete
test programs to blink an LED:
http://www.ccsinfo.com/forum/viewtopic.php?t=42731 |
Bollo
Posted: Mon Dec 13, 2010 4:59 pm |
Thanks for the rapid reply.
#include <18F27J53.h>
#FUSES NOWDT
#FUSES INTRC_PLL_IO
#FUSES PLLEN
#FUSES PLL1
void main(){
do{
output_high(PIN_A1);
output_low(PIN_A1);
This code runs but the delay is close to 4 seconds not 100 ms which makes me think the oscillator is not set correctly. Obviously if I try the osc related fuses in my first post, it fails to compile.
Edit:
Also tried setup oscillator with "OSC_NORMAL" or'd in like the example posted, still the same.
2nd Edit:
After looking at the datasheet (page 36) it also seems the PLL requires a 4MHz input to multiply up to 48MHz therefore instead of PLL1, PLL2 is required to divide the 8MHz int osc down to 4MHz. Oddly though this does not change the delay length, still ~ 4 seconds. So it would appear I don't want to use the "NOCPUDIV" fuse after all. However I still wish to use the USB function so the "LS48MHZ" fuse problem still stands. Perhaps this is set to that by default. Either way (at least firstly) this now seems to be about correctly setting the oscillator. Any ideas where I'm failing?  |
Posted: Mon Dec 13, 2010 6:39 pm |
I don't have this PIC to test, but try the following program and see if works:
#fuses INTRC_PLL_IO, PLL2, PLLEN, NOCPUDIV, NOWDT
setup_oscillator(OSC_8MHZ | OSC_PLL_ON);
output_low(PIN_A1);
Bollo
Posted: Tue Dec 14, 2010 5:12 am |
*** Error 111 "main.c" Line 2(7,50): Unknown keyword in #FUSES "NOCPUDIV"
I hit the unknown fuse problem again with NOCPUDIV.
With or'ing OSC_8MHZ, the clock is now faster, a 1000 ms delay set in code is 6000 ms in real time. Looking at the oscillator block diagram there is a CPU Divider after the PLL. It looks like it's defaulting to divide by 6. The compiler doesn't recognise CPUDIV6,CPUDIV3,CPUDIV2,NOCPUDIV which look like the fuses controlling that cpu divider.
Almost there! Thanks. |
Posted: Tue Dec 14, 2010 5:27 am |
It sounds like two separate problems.
The PLL2 one, which you have already tracked.
I'd suggest though that your device database is corrupted. The code as posted, with PLL2 selected, compiles fine for me on 4.114. Remove, and re-install the compiler. For some 'unknown' reason, sometimes the devices4.dat file gets corrupted, and gives behaviour exactly like you are seeing.
Bollo
Posted: Tue Dec 14, 2010 8:00 am |
| It seems it was the location the compiler was installed to. I copied the PICC folder to another folder outside of program files and then it seem to work fine. I imagine it's due to the security restrictions applied to the program files folder by windows 7. Is CCSC attempting to open files (devices4.dat for example) read/write where it doesn't need to? |
