How to convert dec. to hex. in pic16f819 ?
sorasit46
PostPosted: Sat Dec 11, 2010 5:05 am     Reply with quote
Any ideas on how to convert dec. to hex.?
exe. 43 = 0x2B
thank you
PostPosted: Sat Dec 11, 2010 5:14 am     Reply with quote
Depends what you mean.....
Understand, the PIC, does not 'work' directly in decimal, or hex. It works internally in binary. So when you input a number (typing it in), you have to have code, that accepts the digits, and converts the text sequence, into binary. Once inside the PIC, you can then output this in a huge 'range' of ways. If you 'putc' the value, a single character is sent, who's ASCII value is the number inside the PIC. Or if you use printf, you have then a 'range' of output formats possible. Look at the %x format specifier in printf....
sorasit46
PostPosted: Sat Dec 11, 2010 5:34 am     Reply with quote
I mean how to write source code for convert dec. value to hex. value in my programe,such as built in function.
Johann17943
PostPosted: Sat Dec 11, 2010 5:51 am     Reply with quote
Hi sorasit46
The function for dec to hex is:
int dec_hex(int zahl);
int einer,zehner,ergebnis;
ergebnis=0;
zehner=zahl/10;
einer=zahl-(zehner*10);
ergebnis=(zehner<<4)|einer;
return ergebnis;
example:
hex_value=dec_hex(dec_value);
sorasit46
PostPosted: Sat Dec 11, 2010 5:56 am     Reply with quote
Hi! Jonann17943
Thanks for the help!
but I correct some code.
ergebnis=0;
zehner=zahl/[b]16[/b];
einer=zahl-(zehner*[b]16[/b]);
return ergebnis;
My data is int16,not int.
How to modify this source code?
